I have already replaced my 2000 f250s headlights with halo housings, I’m not much on them so I’ve been looking for a more oem looking housing, but all I can find is housings that have only one headlight bulb in each houseing where as mine have 2 bulbs in each headlight housing, hoping someone can help me out, thanks
A good upgrade is the 2002 clear lens housings. They have 1 bulb that does both high and low beam. A great mod for that stock setup is an upgraded headlight harness and better bulbs like Hellas to take advantage of the extra juice.
I have HID bulbs from DDM, which put out a ton of light, but have a couple cons that need to be addressed. If/when these die I'll go the harness and Hellas route.
Or you could do a downgrade to XL style sealed beam headlights and run LED sealed beam units. If you like the look of the aero headlight housings you can try this.
where did you get the harness that goes from two harness to one
