Check Engine Light
Old Apr 6, 2021 | 10:09 PM
rgp's Avatar
rgp
Check Engine Light
2001 Ranger 4 Liter, 216,000-miles
Got a check engine warning. I downloaded the code.PO442 Evaporative Emmission Control System Leak Detected (small leak). Duhh? Anyone know where that sensor is?
I've found lately that some sensors are simply failing and need to be replaced. I would try replacing the sensor before I try finding a small leak.
I thank you for any help you provide me.
Bob P.
Old Apr 7, 2021 | 04:47 AM
mfp4073's Avatar
mfp4073
90% of the time this code is from the fuel fill cap either not being put on tight enough or the seal failing. If had it come on if it didnt get enough "clicks" and also about 5 months ago I ended up just replacing it (15$ for a ford one off amazon).
Old Apr 7, 2021 | 08:33 AM
Johnny Paycheck's Avatar
Johnny Paycheck
Bob P.
Are they failing or are you ignoring what they are telling you with proper diagnostic troubleshooting?
You definitely wouldn’t be the first here to throw sensors at an issue to find the sensor was doing its job.
Old Apr 7, 2021 | 06:59 PM
rgp's Avatar
rgp
Thanks for the feed back. I'll order a cap and check the hose clamp at the filler neck.
Old Apr 8, 2021 | 05:56 PM
mfp4073's Avatar
mfp4073
Let us know how it goes and what you come up with. I agree, trying to chase down the whole system isnt a fun thought.
jkarne
2004 - 2008 F150
Mar 16, 2011 09:10 PM
jazz77
Oct 30, 2010 05:02 PM
huronwoods
Nov 16, 2009 08:05 PM
frenchf250
Feb 14, 2005 12:06 PM
