1967 Turn/4Way Flasher
I have some questions for you about the 1967 original turn signal and 4Way flasher.
1967 F100
For some background: The truck has been mine for almost 4 years now, however it has been in the family longer than I have. I daily drove it for 1.5 years with minor issues, nothing I couldn't work out. That being said, I do not remember a time where the turn signal was as fast as a "normal" turn signal. I was always very slow compared to modern cars.
Fast forward to this Easter weekend, I had ordered a replacement part (flasher) that I thought was correct and decided to pull the cluster and replace it. I wanted to replace it because it was so slow that sometimes other drivers would not realize I had it on or were slow to realize. So I pulled the cluster and found the "mystery flasher" as other posts and forums have called it. The part # (Ford engineering# / Ford-ID# ?) is : C7TB-13350-A (I pulled it apart and found that some of the wire in the coil was burned but it was functional)
I can't find one online and it has been long obsolete, I read on fordification that this part was a 3-month run and after that, the part was switched to 2 independent flashers (fordification link below)
I also read that people replaced it with the heavy duty cylinder shape relay of the later models and it worked fine. Me being cheap saw a claim that any old relay would do the trick so, I went and got a 2 prong relay from the parts store and hooked it up (just made a spade connector to let the factory wire connect to 2 male vs the original male-female). Now, the lights are constant. I push the indicator left and my left lights come on but never flash, same goes for the right and emergency or 4Way. I think this might have to do with grounding but I am not the best when it comes to troubleshooting circuits. The reason I think grounding is that the original flasher has a wire from the relay to the casing making me think that the casing grounds the relay to the mounting location.
So my question would be, why would a regular, modern 2prong flasher relay make my lights stay on?
Here is what i came up with but i figured a new forum post would get more attention than trying to revive these.
Mystery Flasher? - Page 2 - The FORDification.com Forums
https://www.ford-trucks.com/forums/1...-location.html
I will try to check back here often and answer any questions you may have for me. I can also go get the PN for the new flasher but it's just a generic $4 flasher
Thanks, Ken
The following N.O.S. places show it in their stock. Ford part number C7TZ13350B.Klimesh Motor Sales
563-562-3241
Green Sales
(800) 543-4959
Dennis Carpenter Ford
800-476-9653
you used the words “relay” in your post. The flasher is not a relay. Just a thermal switch.
I bought what I thought was the right part before opening it up. I had to make a 4 hr drive and needed something to work. My only concern with getting the NOS part is that it would be just as slow as the "working" one I pulled out.
Can you speak on the speed at which the signals are meant to flash?
