Coolant flush
Old Apr 5, 2021 | 08:53 PM
muddslinger48's Avatar
muddslinger48
Coolant flush
I’m getting ready to perform a coolant flush along with new hoses and belt. I’m debating on doing Dan clutch and water pump while I’m I there because both are factory from 2000. My concern is that the tap water from my area is extremely hard and has lots of deposits in it. Will this be ok even if I run the truck and flush it with distilled water a few times? Also which ELC coolant do y’all recommend?
Old Apr 5, 2021 | 09:14 PM
pvdiag's Avatar
pvdiag
I am draining/flushing my system out as we speak (changed out oil cooler). I have been using distilled water. In retrospect I would have used tap water for a flush or 2 after the initial charge of coolant was drained. Then go with distilled for 3 flushes. To hedge your bet, remove the block drain plugs (near oil filter and behind starter). About 1-1.5 gallons of liquid comes out of the block (drivers side anyway).
Old Apr 5, 2021 | 09:18 PM
muddslinger48
What coolant do you recommend?
Old Apr 5, 2021 | 09:20 PM
CousinCarl's Avatar
CousinCarl
I'd say yes to replacing the water pump while in there. My water also has a lot of deposits so I used somewhere between 20-30gal of distilled water in my F350 and my X. The looks you get in Walmart with rolling a full cart of water jugs to the register is quite something. I felt super guilty during the pandemic last year when I did the X. I'm just paranoid. I'm sure others here will say it's fine after a final flush of distilled.
I use Rotella ELC. It's readily available and even on sale at TSC for $16.99 right now (at least it was over the weekend when I was in there for some stuff).
Old Apr 5, 2021 | 09:56 PM
muddslinger48
The current color is my coolant is green. Isent the rotella ELC red? Will that hurt anything?
Old Apr 5, 2021 | 10:09 PM
CousinCarl's Avatar
CousinCarl
CAT EC-1 ELC is red. A good, thorough flush to clean the system of the green coolant is necessary so they don't mix.
Old Apr 6, 2021 | 05:31 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Start spraying those block drain plugs a few days before, really helps! CAT ELC really good!
richlars
18
Jun 26, 2018 05:39 PM
jreilly57
20
Jan 17, 2015 07:31 AM
Boo_Daddy
Oct 29, 2013 07:53 PM
kbf1961
Aug 8, 2011 10:26 AM
PrsrizdSD
Aug 16, 2010 11:40 AM
