help identifying wires for NSS
Old Apr 4, 2021 | 08:18 PM
BayStYat's Avatar
BayStYat
I am redoing my entire wiring in the truck. Can someone identify what the wire colors on this plug. The red is for the back up lights? the black for the starter interrupt?
thanks
Old Apr 5, 2021 | 09:55 PM
JEFFFAFA's Avatar
JEFFFAFA
On the red striped wires one is power in from the fuse box and one is out to the backup lamps. The black wires have to be for Start. Below is a diagram for a 1970 (close enough). This does not show Lamp wiring.
Old Apr 6, 2021 | 07:32 AM
BayStYat's Avatar
BayStYat
thank you. I used a continuity meter on the red and blue, when in park the red and blue had continuity. When i shifted out of park i lost continuity. Same thing for the reverse lights but used the black wires.
was this an accurate way to find the correct wires?
Old Apr 6, 2021 | 09:18 PM
JEFFFAFA's Avatar
JEFFFAFA
Yes it is. Good job. Actually the lamp diagram listed the backup lamp wires as black and red. But since you are using an aftermarket switch I figured the manufacturer used blue and red.
66with352
Sep 6, 2020 01:35 PM
dsaldivar
Electrical Systems/Wiring
Sep 20, 2015 03:50 PM
ZachManXLT
1997 - 2003 F150
May 24, 2015 06:40 AM
2002_escape
Jan 3, 2014 03:11 PM
nalts
22
May 15, 2013 01:02 AM
