2.9 starting conundrum
Old Apr 3, 2021 | 08:24 AM
stevegintn's Avatar
stevegintn
I am trying to resolve a starting and running issue with my '88 2.9 Ranger. It's a new crate engine with less than 10k miles, I put in 10 years ago.
On a cold start, it cranks and starts fine. Idle or drive to warm up, it will stall out at a stop. Then trying to restart, starter will drag, like weak battery.
Let it cool off, repeat same scenarion above.
It's almost like it's losing ground? (had same issue with my '02 Sportrac 4.0)
Any ideas?
Old Apr 3, 2021 | 08:46 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Perform the KOEO test to check for fault codes. It might help get you started on where to look. The hot start issue sounds like the timing is off. What is the base timing set at and was the spout removed when it was set?
Old Apr 3, 2021 | 01:33 PM
stevegintn's Avatar
stevegintn
Yea, I thought about timing - have not checked it yet but spec is 10 BTC. What is the "spout" to disconnect when timing?
Old Apr 3, 2021 | 02:03 PM
My4Fordtrucks
Information in this thread: https://www.ford-trucks.com/forums/1...rformance.html
The pcm is always making adjustments to the timing while running. Removing the spout takes the computer out of the loop. It is located near the distributor on the passenger side.
Old Apr 3, 2021 | 10:30 PM
stevegintn's Avatar
stevegintn
Many thanks, My4 - if you couldo do one more thing for me, please? Back off a little and point to that pcm connect and shoot me another pic?
I want to be sure I can find it.
Old Apr 4, 2021 | 09:08 AM
My4Fordtrucks
That picture was not mine. I found it in another thread. Here is a picture from my ‘89 Bronco II.
Spout is circled
Old Apr 4, 2021 | 02:53 PM
stevegintn's Avatar
stevegintn
Ok, what you have circled looks like my pcv valve.
In my photos, the top circeled plugs into side of distributor, the middle circled plugs into valve cover (pcv valve, non-electrical), and bottom circled is plug of unknown origin (yellow wires). I cannot see anywhere it would plug?
Which one?
Old Apr 4, 2021 | 04:57 PM
My4Fordtrucks
The pcv valve is behind what is circled.
Old Apr 4, 2021 | 07:24 PM
stevegintn's Avatar
stevegintn
Ok, then what your last photo shows is the same plug in my photo at BOTTOM encircled (2 yellow wires). As I said mine is already disconnected.
What am I missing?
Old Apr 4, 2021 | 07:29 PM
My4Fordtrucks
I can’t see the whole connector in the bottom picture so I don’t know what you mean by disconnected. Is the spout not there? You just have an empty connector?
Old Apr 4, 2021 | 08:26 PM
stevegintn's Avatar
stevegintn
Ok, what you are pointing to, does it plug into something, or maybe the top just pulls off?
i don't see anything like that on my 2.9
The plug I showed (2 yellow wires) is one-half of a connector (plugs to SOMETHING?). I just cannot see where.
I will get a better pic in the morning.
Old Apr 4, 2021 | 10:39 PM
My4Fordtrucks
The spout is plugged into the connector in my picture. Remove it to set the timing.
Sounds like someone removed the spout which means that you only have 10° of timing since the computer cannot control the advance without it.
Old Apr 5, 2021 | 07:12 AM
stevegintn's Avatar
stevegintn
Yep - found a YouTube video and finally figured that out.
Pulled cap off spout and attempted to set timing with gun. It appears to be correct now but running rough (missing and backfiring) so cannot be right?
Also, turned key off then back on - dragging no start - turned key back off and DIESELING (turning over with key OFF). Had to disconnect battery cables (was smoking over-heating battery ground cable). WTH?
Old Apr 5, 2021 | 06:32 PM
My4Fordtrucks
I’m not sure if they are available new. I’d probably go to the junkyard to get one.
Old Apr 5, 2021 | 06:38 PM
stevegintn's Avatar
stevegintn
Ok, not necessary (whew) - see my previous post
