Priority Code?
Old Apr 2, 2021 | 08:18 PM
rebauto's Avatar
rebauto
Priority Code?
Just placed an order for a 2022 F450 Lariat this morning. Order sheet says priority code 11. Anyone have any insight into what 11 even means?
Old Apr 2, 2021 | 09:02 PM
440 sixpack's Avatar
440 sixpack
On retail orders 10 is the highest priority a dealer can give. so probably they gave their inventory a 10 and you an 11. but 11 isn't bad at all. I still wouldn't plan on seeing it anytime before August.
Old Apr 2, 2021 | 10:34 PM
rebauto's Avatar
rebauto
Thank you, makes sense I suppose, was hoping it was the other way around, but it is what it is...
Old Apr 3, 2021 | 12:16 AM
2Wheel-Lee's Avatar
2Wheel-Lee
My dealer is fairly large, and they said my 2022 order was a priority 10. Just the same, he said I may see the truck in September.
Old Apr 3, 2021 | 07:06 AM
BulletStopper's Avatar
BulletStopper
Mine is also priority 11. The dealer said 12 weeks, but I feel that is way overly optimistic. I told the wife June or July at the earliest.
Old Apr 3, 2021 | 08:45 AM
440 sixpack
I ordered mine a few weeks ago and got a G2 priority ( fleet account ) , which means 2nd week of July. so I think it's unrealistic for anyone ordering to expect our orders to be built before the dealer gets a run of inventory headed their way. I hope to see mine in August but I think September is more realistic given the shortages of parts.
Old Apr 3, 2021 | 08:46 AM
rklavoon's Avatar
rklavoon
Agreed. Here is the production info.
I ordered mine 3/26 and am shooting for Labor Day. Anything before that I will be happy.
  • 03/15/2021 - 2022MY Order Bank Open Date
  • 04/22/2021 - 2022MY Scheduling Begins (KTP)
  • TBD - 2022MY Scheduling Begins (OHAP)
  • 06/01/2021 - 2022MY Job #1 Date (KTP)
  • 07/12/2021 - 2022MY Job #1 Date (OHAP)
Old Apr 3, 2021 | 12:26 PM
vancouverbrian's Avatar
vancouverbrian
I thought this web article describing the ordering process and priority codes was interesting. I thought I would add a link so others here could read it. And to add to the discussion, I think the start up of production year 2022 may slip because of the cut back of a shift at the Louisville Truck Plant due to a shortage of computer chips and they have accepted orders for the 2021 production year.
Ford Vehicle Ordering & Scheduling Process - Ford Motor Company Discussion Forum - Blue Oval Forums
Old Apr 3, 2021 | 02:58 PM
rebauto's Avatar
rebauto
Good info, thank you.
Old Apr 4, 2021 | 12:57 AM
digz's Avatar
digz
My fleet order for a F450 chassis cab was 20.....this mean hell will freeze over before I get it? Lol
Old Apr 4, 2021 | 09:18 AM
vancouverbrian
I saw this article from FORD and it described a true Fleet Order like you describe. I will add it for everyone to read. While you have a desired production timing for your order, it says clearly that they do not guarantee a build week.
Priority Codes (ford.com)
I will add this article also that describes the process in more detailed manner.
The Ford ordering process explained from start to finish | Ford Focus RS Forum
I did read that code 80 is a FORD inventory order for dealers for stock.
I hope this is helpful to those here in the forums.
Old Apr 4, 2021 | 10:30 AM
440 sixpack
Yes I think all they guarantee is that they'll try.
digz , if you have a fleet order they should give you a build week and that is your priority number. maybe 20 is just a default code until they set it. my fleet priority code is G2 and it came 24 hours after the order was placed so you might check back with them.
Old Apr 5, 2021 | 12:41 AM
digz's Avatar
digz
Ok ill check it out 👌
Old Apr 5, 2021 | 07:50 AM
vancouverbrian
My read on these priorities is that unless you are real fleet customer, the fleet department will put the order in the same as retail order. That means the priority number will be like 10 to 20. The numeric code like G2 is simply a build week that is the desired build week asked for by the dealer. Reading from the articles that I posted, the codes change yearly to correspond to the model number months of production. And fleet orders have a priority/allocation within the system. No guarantees are given to the dealers that the build will happen that week. I ordered my truck in 2017 thru the fleet department and was assigned a retail priority.
Old Apr 5, 2021 | 08:15 AM
vancouverbrian
I went back to look at my links and they now require passcodes.
Here are some more:
2021_Fleet_PriorityCode_Calendar.pdf (ford.com)
Scheduling Bulletin 03302021.xlsx (ford.ca)
I added this one as it lists at the end, all the execs and phone numbers within FORD
2020+Fleet+Preview+Guide+Joe+Cotton+Ford.pdf
This was cut and paste from a long post:
Fleet- Fleet doesn't go through the allocation system. Fleet gets a percentage of the weeks production and schedules by order date so this eliminates any time differences between dealers and also allows them to sell to fleets without using a allocation that should go to a normal customer. Fleet unit sales don't count to earn allocation either.
Internal FORD ordering and allocation is hard to understand and complicated. I put these thing here to help others learn and understand. But noone really knows it all unless you are on the inside.
