Sponsored by: Real Truck
Maybe a fuel filter?
Old Apr 2, 2021 | 01:13 AM
Gunpowder Danny's Avatar
Gunpowder Danny
Trailering
I have a 2002 f250 7.3 with 150k.it has a ts perf.6 pos. tune. It started out falling on it's nose shortly after start up. Now it starts runs for about a minute, then dies. Could this be a fuel filter problem? This is my first diesel so I'm new at this.
I should add that after it dies, it won't even try to fire when I turn it over. And when it first started doing this, if I could keep it running thru the sluggish running shortly after taking off, it seemed to pull out if it and run fine.
Old Apr 2, 2021 | 09:18 AM
Gyppo Logger's Avatar
Gyppo Logger
What kind of shape is your fuel tank in? Does your fuel level effect the symptoms? Have you had a chance to check your fuel pressure, maybe a lift pump might help.
Old Apr 2, 2021 | 10:28 AM
bwguardian's Avatar
bwguardian
When was the last time you replaced the fuel filter? Also, turn the key on and listen to see if you hear the fuel pump humm for a few seconds which is located on the inside of the frame rail just under the drivers seat. If you don't hear it, touch it to see if you feel a vibration that it's working. If it's making a gurgling noise, it's probably on its way out. It could also be the filter socks in the tank being dirty.
Alex Church
Feb 18, 2020 08:30 AM
menze46
Oct 19, 2019 10:33 AM
ClaytonSmith
Aug 18, 2013 08:08 AM
Ex1900Driver
May 17, 2008 05:07 PM
TallPaul
Dec 10, 2003 10:23 PM
