2 Qs Changing oil brand and squeaky mirror
Old Apr 1, 2021 | 08:39 AM
Louis Lewis's Avatar
Louis Lewis
Greetings to all.
2020 Lariat Super Duty. I've been using Mobil1 Extended Performance Full Synthetic 5W-20 oil. Now, I'm about to use 5W-20 Motorcraft synthetic blend motor oil which they claim meets Ford WSS-M2C960-A1. Question is, does mixing brands affects oil performance?
Also, my "Trailer Tow Mirrors" have a squeaky sound when are deployed. Should I go to dealer for that or, which I will definitive prefer, is there a way to lubricate it? I'll rather learn how to keep those mirrors well lubricated since they open and close very often.
Thank you in advance for your comments and advice.
Louis
Old Apr 1, 2021 | 09:07 AM
ford390gashog's Avatar
ford390gashog
Well neither oil are correct for your application as there is not a 5w20 oil recommended.
Old Apr 1, 2021 | 09:15 AM
440 sixpack's Avatar
440 sixpack
If you're asking if you can use two oils at the same time yes, but I don't see it as the best idea. if you're asking will the oil left after draining it is a problem absolutely not.
Old Apr 1, 2021 | 09:23 AM
Louis Lewis
Thank you for your comment.
You sent me to double check the manual. I have a 2020 Ford F-250 Super Duty 6.2L gasser. The book says oil capacity 7 Qt. and to use Engine Oil SAE 5W-30 Synthetic blend Motor oil. with a specification WSS-M2C946-B1. I think the oil I currently have (Mobil 1) meets those specs. I'm concerned changing brands. Any comment about that?
Old Apr 1, 2021 | 09:30 AM
Louis Lewis
Thank you for your answer.
Yes, that's what I'm asking for today. Currently, I have Mobil 1 and I will fully replaced it with Motorcraft synthetic blend. Somewhere I read they do not recommend changing brands and "mixing" the oil change residue with new fresh oil.
Old Apr 1, 2021 | 09:42 AM
440 sixpack
That's an old wives tale.
Old Apr 1, 2021 | 10:24 AM
HRTKD's Avatar
HRTKD
Even AMSOil says you can mix brands. They point out that a full oil change with their oil gives you the best benefit. You'll never get every drop of old oil out of an engine unless you take the engine apart.
Old Apr 1, 2021 | 10:42 AM
ford390gashog
If you currently have 5w20 in the truck it doesn't meet the specs. Brand is not really relevant, it's the specs that are.
Old Apr 1, 2021 | 03:36 PM
BillyE's Avatar
BillyE
Use an oil with the right spec at the recommended weight for your application. It’s that simple. Brand doesn’t matter
Kamhillbilly
2015 - 2020 F150
Jan 30, 2020 08:27 PM
Patnoel
Oil & Lubrication
36
Aug 26, 2016 02:23 AM
ajbjeep
6.7L Power Stroke Diesel
23
Oct 7, 2015 07:13 PM
DR JOE
Oil & Lubrication
Jul 30, 2006 02:01 PM
holland501
Oil & Lubrication
Oct 27, 2005 04:50 PM
