Hello, I'm looking for some advice... I'm currently doing a restoration of a 1994 f150 with the 302 v8. when I got the truck the previous owner had the original two catalytic converters but had deleted the muffler. Just recently I had the larger cat delete and a muffler put on. The cat I have left combines the two exhaust manifolds and pushes the exhaust into one pipe leading to the muffler. I was told when I went to do this it would effect my gas mileage nor my horse power. But after having this done, my truck seems to do better on gas mileage and has horse power. So I'm wondering if I should go back and remove the last cat, replace the old one, or just leave it be. Any advice would be greatly appreciated and thanks for you time.
ive never thought any mufflers or cats to increase fuel economy or power since its really just more places for back pressure in your exhaust, if it is going up and you want to make it better you could install the other one(s)
There's a good chance your original cats are on the way to being plugged. That's why removing the one cat provided a bit of mileage and power. I agree with Rla2005 that the remaining cat should be replaced with a modern one.
Catalytic converters have become much better and you may notice that modern cars do not have the air injection pump that seems to get so much hate in our trucks. Apparently, modern cats do not require the additional air to be effective, but that is not sufficient reason for an emissions delete should you be subject to one.
My neighbor has an identical truck to mine- 96 f-150 with 302 and automatic. He says he removed all the catalytic converters and his truck runs better, but it won’t pass emission test. Duh. Do es anyone here have a system like my neighbor’s? Does it truly run well? Thanks
I’m not entirely sure what you are asking. If the catalytic converter in your neighbors truck was partially clogged then I can see how removing it made an improvement. I had a high flow converter installed in my exhaust system. I see no reason not to have one.
What part of the emissions test did it fail? Did it also fail the visual if your state does that? I would think that a ‘96 with an automatic is OBD- II so then the check engine light is probably on because the sensor after converter is not seeing the reduced emissions from the catalyst
This. The truck's engine computer is probably freaking out because it measures catalyst efficiency, or lack thereof in this case.....
Such a timely question sorry for the sort of hijack, but it is about catalytic converters . I now have the 351W under the hood and the 302 in the bed. Sadly the exhaust does not bolt up like I was hoping, so I am now trying to figure out if I really need to spend nearly $700 for stainless cat and tubes from Magnaflow, or are the walker or flow master sufficient at a fraction of the price? One of my concerns is sound. What I am ultimately looking/listening for is a nice low growl without any crackling when I get on it or running down the highway.
Sadly the exhaust does not bolt up like I was hoping, so I am now trying to figure out if I really need to spend nearly $700 for stainless cat and tubes....
It won’t bolt up since the 351 is taller and wider than the 302. Is that what problem you’re having? Other than the “Y” pipe everything else should work.
And the angles of the driver's side connection are different between the 2 motors. It was looking like a little splice and dice in the cross over tube could maybe fix that, but Nooooooo.
Anyway, I am thinking that it would be nice to just update everything from the headers back, since it is a fresh rebuild motor and the current exhaust is, well, rather well used. cat back is 15+ years and lord knows how many miles, the cats are probably original.
So back to the original question, it it really worth twice the cost for the full stainless... magnaflow? What about Walker at about 2/3s the cost. I know there will be some sound dampening, but do the different brands have different tones like they do in the actual muffler end of the system?
Can’t help there either. A local shop fabricated the “y” pipe to a high flow Magnaflow catalytic converter the. Into a cheap chambered muffler. I don’t get any drive but from what people tell me it is kind of loud. It doesn’t sound loud in the cab.
