10R140 4th Gear Deceleration Noise
#106
Update
Just an update. Tomorrow is 50 days my truck will be at Ford. Rear end has been there for approximately 12 days waiting on nuts and bolts as everything is 1 time use hardware and everything is backordered. Corporate will not reimburse any payments until the vehicle is fixed which is not what the first customer service center representative i spoke with told me. Still no loaner.
#107
#108
So I got my truck out of the shop with the grinding sound on the 5-3 down shift. They worked on it. Got somewhat better and according to advisor I have to drive 500 miles for full effect. He stated they have seen this before on the 10 speed trannys. Here is the info from the ticket.
“Auth code 1777, 1862. Verified harsh downshift from 6 to 5. Checked oasis and found Ssm 50261 is related to customer concern. Vehicle has less than 5000 miles. Performed accelerated main control break in routine. Verified repair. Test Drove. Informed customer accelerated breakin may take 500 miles for full affect. Instructed customer to call after 500 miles if still experiencing issue.”
#109
What do you think after driving it?
#110
#111
I actually challenged them on that but the stupid service manual clearly stated 1k miles after break in acceleration. They showed me. The dealer said 500 should fix it. It sound better but different. Instead one rather loud and long grinding or whatever sound on 5-3, It was softer 3 short sounds for each gear and nothing really when applying moderate breaks. I’ll go the 500 and see. Fairly happy to just have a service ticket that acknowledges the issue, sometimes even getting that is a challenge.
The following 2 users liked this post by Wideload:
#112
The following users liked this post:
#113
Latest video, with new M300 installed.
2022 Ford F350 DRW M300 Replace With Part Numbers - Excessive Metal Showing up In Fluid 1,350 Miles - YouTube
#114
#115
#116
#117
any update on this. My truck has 2500 miles and is doing the same thing. My dealer has a transmission on order for my truck but if it’s something that can be fixed with a re program I would like to go that route.
#118
what do you mean update? Did you see the date of his post? Did you read it? It sounds like they did a "break in procedure" on a valve body. Not necessarily any pcm reprogramming.
#119
i did see the date. Was just curious if in fact the noise is gone. Mine is doing the exact same thing so would like to know. Is that break in procedure something that can be done on our own or dealer has to flash something into the tcm
#120
I take a little comfort knowing that maybe this is only a break in issue and there isn't anything terminally wrong with the
