What's this called?
Old Mar 31, 2021 | 07:53 AM
DavenTn's Avatar
DavenTn
What's this called?
Appears to be a vacuum module of some sort located behind the electronic heater/AC control.
Old Mar 31, 2021 | 12:29 PM
2002Ex's Avatar
2002Ex
The Automatic Temperature Control solenoid and Manifold:
  • is located in the instrument panel behind the audio unit.
  • uses solenoid-type valves to distribute vacuum to the vacuum control motors and the heater control valve based on the EATC module settings.
Old Mar 31, 2021 | 06:59 PM
Rainmaker1's Avatar
Rainmaker1
I call it a "Thingy over there"...
Old Apr 1, 2021 | 06:39 AM
DavenTn's Avatar
DavenTn
Using your description and nomenclature ... nothing comes up. I know what it does, but I don't know what to call it. I'm trying to find a diagram of it.
Old Apr 1, 2021 | 02:18 PM
2002Ex's Avatar
2002Ex
The heater control valve is actuated by the air inlet door vacuum circuit (manual climate control) or the heater control valve vacuum control circuit (EATC). When the heater control valve is closed (full vacuum), coolant flow through the heater core is shut off and A/C cooling efficiency is increased.
Old Apr 1, 2021 | 05:11 PM
DavenTn's Avatar
DavenTn
Totally understand the operation, completely understand how to access the part... after all I took a picture of it, but thanks for your help.
Old Apr 1, 2021 | 05:45 PM
01__Excursion's Avatar
01__Excursion
The info above from the service manual is suggesting that remove and replace are your only options, and that there is no internal schematic, or diagram of the internals. Looks like it's a replace only part.
Old Apr 2, 2021 | 08:22 AM
DavenTn's Avatar
DavenTn
Appreciate that.
I did find a related thread for F150 so I've got a few more details. Thanks for yawls help.
Old Apr 2, 2021 | 09:58 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Dave, what are you wanting to do with it? I have the diagram...I used it to re-route my vacuum hoses so I could control when hot coolant goes through my heater core when I want it to in summer.
Old Apr 3, 2021 | 08:16 AM
DavenTn's Avatar
DavenTn
I'm getting some issues with my panel-defroster air flow. Vacuum is not an issue, I have no leaks. The system changes from panel to defrost on it's own, at times... sometimes works fine with no issues. Right now I have the dash off and plan to 'forensically' check the system.
My system is the EATC with the separate solenoid & vacuum manifold. There's a self diagnosis procedure for the head unit, that I'll do today. I also have a vacuum chart for each position. If you have anything else, it would be appreciated, but right now I 'm still trouble shooting.
Old Apr 3, 2021 | 09:04 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Sounds like you have what you need, and my diagram might not apply to yours with EATC.
Old Feb 18, 2024 | 08:57 PM
Excurvelle's Avatar
Excurvelle
Bringing this back up.
Dave, did you ever find the issue? Was it the vacuum control solenoid?
DidieX
Sep 24, 2020 06:03 PM
Seth Matthews
Dec 23, 2018 03:20 PM
loquito
May 9, 2014 09:01 AM
Luch
Apr 12, 2013 09:00 PM
precisiontile
Mar 7, 2012 10:52 PM
