Sponsored by: Real Truck
coolant temprature
Old Mar 31, 2021 | 06:33 AM
Dieselcyrus's Avatar
Dieselcyrus
coolant temprature
08 F25O 6.4l====oK, the temperature gage on my BULLY DOG tuner once engine warmed up always stayed at 188 in city driving or highway upto 65 mph and over 65 mph, it went to 190-192...but it would stay at those temps steady. two weeks ago i noticed couple of things : 1) every time i accelarate in city or highway it fluctuates from 188 to 192 in city and 190 to 197 in highway over 60 mph. IT seems its sensitive to acceleration AND tends to run higher than it did before at same speeds. 2) it constantly fluctuates, doesnt stay steady
NOTE: Instrument panel gage needle stays almost in the middle where it always has and the truck drives otherwise normal. no issues so far
can this be just a bad BULLY DOG TUNER issue or can it something else?? any thoughts!!! thank you.
Old Mar 31, 2021 | 08:20 AM
Just Strokin's Avatar
Just Strokin
As long as it doesn't "boil over", then stop worrying is my theory on water temps. Water under pressure such as the cooling system will increase the temp at which water boils. With the right mix of coolant and water also with a good radiator cap, you could have the water temp as high as 235 or higher without it "boiling over".
The temps will fluctuate as the thermostat opens and closes. The rise is temp under acceleration sounds normal to me as the cylinders generate more "heat" as you induce more fuel to increase the speed of the truck.
If you are worried about it, you might change the thermostat and see if that solves the problem. I highly doubt it will but to ease your mind, you can change it.
Old Mar 31, 2021 | 08:25 AM
Dieselcyrus
thanks
thanks bother. i appreciate your response. as a matter if fact i had order bith a Motorcrat radiator cap and the coolant reservoir caps. figured they r 13 years old and a cheap fix that is worth it. thanks again.
Old Mar 31, 2021 | 11:52 AM
99powerstrokedF250's Avatar
99powerstrokedF250
If I recall, these sensors also aren't the most accurate, and will easily fluctuate 2-4 degrees even if the water is at steady-state. The temps you're reporting look good, I wouldn't worry too much about it.
Old Mar 31, 2021 | 02:35 PM
Dieselcyrus
THANK YOU!
Old Apr 1, 2021 | 11:08 AM
senix's Avatar
senix
normal. I ran a 6.4 for over 5 years. As long as your degas bottle does not have white crust on it and nothing to worry about.
Needle is an idiot guage in disguise, but will move with heavy towing. Just right of center is 220F.
ezzmoney
17
Jan 23, 2019 06:02 PM
maxine
Jul 21, 2015 12:27 AM
syracuse
Mar 23, 2006 12:58 AM
abelmoreno
Dec 10, 2005 10:57 AM
dave98
Apr 17, 2003 06:40 PM
