Sponsored by: Real Truck
vibration
Old Mar 28, 2021 | 04:38 PM
gjfowlerjr's Avatar
gjfowlerjr
vibration
I have a 2006 f250 4x4 with the 6.0 and about 36 mph it starts to vibrant but then when i lift the throttle the vibration stops and it starts back up when I get back on it, any info would help thank you
Old Mar 28, 2021 | 05:02 PM
Gyppo Logger's Avatar
Gyppo Logger
Just a few threads down a guy was talking about his doing the same but at almost twice the speed, ended up being U-joints. Did you just put a spare on or get new tires? Check the other thread. Could be tires out of balance if you lost a wheel weight.
Old Mar 28, 2021 | 05:19 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Had this problem on the last truck I agree with Gyppo Logger. Check the drive shaft and even the center support bearing while you are down there. Block the truck and brakes off in neutral and give everything a good hard wiggle in all directions.
Old Mar 28, 2021 | 06:05 PM
gjfowlerjr's Avatar
gjfowlerjr
did all the checking u joints changed tires and still doing the same I have rev the engine to same rpm in neutral no vibration and the drive shaft is 1 piece no center bearing
Old Mar 28, 2021 | 06:34 PM
Gyppo Logger
Did you try grabbing your front wheels at the top and push/pull hard and see if they move? Front wheel bearing check?
Old Apr 17, 2021 | 01:21 AM
gjfowlerjr's Avatar
gjfowlerjr
vibration
thanks guys for the heads up I had to take the rear axle part of drive line off to find problem it was a cap ready to go now there no vibration
Old Apr 17, 2021 | 01:25 AM
AK FORD GUY's Avatar
AK FORD GUY
Glad you got it fixed up and running smooth again
Old Apr 17, 2021 | 09:45 AM
Reel Kahuna's Avatar
Reel Kahuna
I read this years ago but never tired it but thought I'd share.
Place a glass of water on the floor and as you drive then notice.... if it "sloshes" then it's the wheels/front end, if it "ripples" then it's your drive train (transmission, differential, driveshaft, axle)
Old Apr 17, 2021 | 10:41 AM
Veteran: Navy
Are you saying the C-clamp holding the joint in??
I may have not had enough coffee yet but I think I am on the right page for the explanation.
Old Apr 25, 2021 | 05:47 AM
cmaupin's Avatar
cmaupin
glad to hear you fixed it, Do you care to give more details of the fix you did and found. Thanks
fastgnat
Feb 9, 2011 09:27 AM
jmolin
Feb 23, 2007 03:14 PM
ultramax21
2004 - 2008 F150
Jul 27, 2004 10:35 PM
