FORscan, iPC module missing???
Old Mar 28, 2021 | 12:48 AM
Jodofab's Avatar
Jodofab
Hey guys, I have changed out the fuel tank on my 2019 and uploaded the FORScan program (latest version 2.3.39) onto my laptop. My interface Module is the USB hard wired with the high speed/medium speed switch. After uploading my trucks program modules, the IPC (instrument panel cluster) module can’t be found... I’ve tried using the HS/MS switch in may ways and still no IPC module. Has anyone had this problem or know what I’m doing wrong? I’m so frustrated and your help would be appreciated.
Old Mar 28, 2021 | 07:07 AM
encmerk's Avatar
encmerk
The first question is was it visible before? If not I suggest a different interface cable. If it was visible previously, I would try to restart the computer and reconnect the cable, following the steps you used to find it previously. It may be a limitation of your cable, and need to pick one that is recommended.
Old Mar 28, 2021 | 07:31 AM
NC Spuds's Avatar
NC Spuds
There’s a note in forescan about removing vehicle profiles after installing the latest version. I don’t know if this might cause your issue, but did you do that step?
Old Mar 28, 2021 | 07:43 AM
Jodofab's Avatar
Jodofab
Smile
The IPC module never uploaded. I’ve got another cable showing up today from Amazon..hopefully this will do it. I’ve got several more things that I want to modify in that module. Thanks for your reply
Old Mar 28, 2021 | 07:46 AM
Jodofab's Avatar
Jodofab
I did not remove the profile.... however I did reset my PCM and lost my radio presets, Doh!
Old Mar 28, 2021 | 06:38 PM
Jodofab's Avatar
Jodofab
I have tried both of these interface modules with the same result. No IPC module located. I’m at wits end... any more ideas?
Old Mar 28, 2021 | 06:45 PM
ford390gashog's Avatar
ford390gashog
Clear the profile, don't allow it to use a saved profile. Then attempt to connect with the USB adapter again. Make sure your extended license is current.
Old Mar 29, 2021 | 08:34 AM
Jodofab's Avatar
Jodofab
I didn’t realize the trucks profile is saved. I’ll check into it tonight. Thanks for the tip.
Old Mar 29, 2021 | 08:59 AM
Poncho450's Avatar
Poncho450
I you’ve used FORScan previously, you’ll generally see a profile pop up on the next use showing truck year, VIN, etc.
Old Mar 29, 2021 | 09:23 AM
Jodofab's Avatar
Jodofab
I received a response from FORScan and it appears I didn’t use my switch properly during the first connection (upload profile). If this happens, your vehicles profile won’t upload completely leaving several modules out. FORScan only scans your PCM the first time to save time each time you re-enter the system. I opened my profile tab and deleted it. I will try again tonight with my new OBDLink EX connector.
Old Mar 29, 2021 | 10:10 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Also make sure your firmware is up to date on the EX
ZooDad
Old Mar 29, 2021 | 10:42 AM
cparks's Avatar
cparks
I had to do the same exact thing when adding the heated steering wheel module. Reset the vehicle profile and it worked fine.
Old Mar 29, 2021 | 11:37 PM
Jodofab's Avatar
Jodofab
Thanks guys for all your help. All is good now. Pandora’s box is now officially open 😜
Old Dec 10, 2024 | 07:28 PM
Jacobcov1's Avatar
Jacobcov1
7th Gear
I’ve followed this thread and none of it works for me. Any ideas?
Old Dec 11, 2024 | 10:14 AM
acdii's Avatar
acdii
I had same thing happen on my 24. Had only a few modules show up and had saved the profile. My dongle needed an update, so ran that, and tried again, same results. I deleted the profile and reconnected, then everything was good. First step before connecting, update the dongle, then update Forscan and license, then connect to truck and scan. Remember to save everything you connect to in a folder and call the folder something that details that its the original AS Builts. Never store altered AsBuilts in the same folder to prevent mistakes.
