Persistent misfire code P0307
BTW, it's "moot" point. Mute means the point is soundless, not irrelevant.
Good luck with your code.
Bottom line is I don't have a clue what it takes to reach these new engines for a compression test, and really don't want to. I don't have the ability or stamina to climb up and around to do so. I do check the oil , as I can just reach the dipstick. The dealer isn't doing Free oil changes now but It isn't that much more than I can buy the materials for and rotated the wheels now for $15.00 Heck I wouldn't rotate the wheels for that 20 years ago.
TJ
If your Snap-On can display a signal showing the coil firing voltage pulses assuming you have the correct cabling, it would show the loss of voltage on that cylinder if that is the cause.
It then would put the failure as electrical in nature.
Otherwise, a random failure usually would not be thought of as a mechanical failure that comes and goes, but anything in possible.
You found out that having a Scanner of any level does not guarantee success if there is little experience behind interpreting what it shows.
Issue:
1. A drivability.
2. Dash alarm or indication.
3. A code to back it up.
4. What does the code indicate?
5. What to check out by scanning checks with tools.
6. Verifying the cause.
7. Doing the repair and checking again for the same failure or drive cycle long enough the be sure the repair was the cause.
Doing owner upkeep is a different story as to ability, tools to test with and parts to make the repairs.
It's all a perspective on expectations, experience, diagnostic and support tools as to success.
Even dealer service short cuts some of the above and does a hope and guess routine that causes a comeback for the same issues over again.
Modern vehicle technology has about run ahead of owner capability to even the point they don't know all the features the vehicle has been equipped with let alone different model levels within the same line.
I'm not trying to be insultive but bring a different look at what may be the case for everyone who reads this.
One example is I have been tracking my 5L passing of some not a lot of oil from the dip stick full mark.
Over 20k miles, a pattern is emerging that is far different than is being talked about on these forums and certainly would be disagreed with if I were to explain it without enough proof over time. Here again, it takes knowledge of the difference in how the motor was designed, the motives behind it, and a possible decisions but cannot prove it at this point.
Enough for now but just to offer some other points that are not being used as part of the overall picture.
Bring up phases like WHY this and that, my other vehicles did not, the design is faulty etc does not cut it and is a narrow minded approach.
If one does not like a vehicle, get one that is perfect in your mind. I believe you will look a long time to find one.
Issue:
1. A drivability.
My code is P0307 - misfire #7
The snapon tool referred to in the thread is a compression tester adapter meant to screw into the sparkplug location that doesn't fit and not because its not long enough.
Is the scanner your referring to an OBII scanner?
I never complained about the design, I just want to diagnose the problem.
Code P030x is the correct 4 DIGIT format.
X = the cylinder number.
In your case it is #7 or P0307.
If it were a V10 motor, the code would be P0310 for cylinder 10, if that cylinder was misfiring.
(If) your code was P0357, The Coil circuit for that cylinder has a fault.
See what I mean about interpreting the codes?
Codes 035x and 030x are totally different in meaning, but both would be a misfire as in 'no spark' or slow rotation time for two different reasons.
These two different formats are detected by two different software sensing programs.
1. The 30x misfire is detected by measuring Crankshaft rotation time.
2. The 35x is an electrical monitor in the computer looking at each coil performance.
See how different they are?
Good luck.
I took it to my local mechanic to have them do the compression check, he said all cylinders were in the acceptable range but didn't have the numbers to share with me. He said he couldn't find a vacuum leak and is at a loss as to why it's misfiring, bye bye $200.00
I purchased a smoke tester and I couldn't identify a vacuum leak. I recently purchased a nice Ancel car scanner in an attempt to solve this mystery. The problem is I don't know what most of the results of these tests mean. What the scanner did tell me that I could understand is the engine continually misfires any time the engine idles below 600 rpms, in fact it always reads "Engine RPM at time of last misfire" 596 rpm.
Can someone point me to the right scan tests that can be performed to help narrow down where the fault is? As an example one of the data stream tests "Variable CAM Timing Bank 2 Exhaust status" "No Fault" - but it doesn't show me any results for Bank1? Why is it not reading Bank 1?
Right there ID's the issue.
Blinking CEL tells you that ignition failed on that cylinder. Blinking tells you the cat on that bank is subject to burning fuel in the cat and causing damage to the Cat.
In reverse highly suggests an electrical connection/wire/harness issue due to the motor rocking in it's mounts.
The intermittent is from the same cause. Movement!
