CCV Reroute 2019
Old Mar 26, 2021 | 12:27 PM
mattymax's Avatar
mattymax
CCV Reroute 2019
Just looking for feedback on the CCV reroute before I purchase it for my 2019.
looking at the SPE with the internal catch cam option. Let me know. Do you guys get oil drip or a ton of smoke under the truck
If I were to route it to the exhaust what kind of port would I need to bring a rubber line to the exhaust without it melting
thanks
matt
Old Mar 26, 2021 | 01:54 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
We are going to be stocking these. Currently no leaking from our shop truck with the OEM box vented. We will be adding the catch and reroute to our shop truck!
Old Apr 3, 2021 | 05:19 PM
SDER1's Avatar
SDER1
I have SPE's internal CC with an off brand CCV reroute kit. I noticed a reduction of smoke, however ambient temperature will determine this too. Every now and then I see a drip, but also with the current weather and experience from my 6.0 with a reroute - condensation may form in hose. I've only noticed some drip after a 8-10 hour interstate drive averaging 70+ mph. Otherwise no complaints and I know my intake is not accumulating an oily film combine with EGR laden fumes.
Old Aug 9, 2021 | 01:39 AM
nm1sks's Avatar
nm1sks
No oil drips but fumes not pleasant. Routed to side of wheel well. You can buy the longer 5ply silicone hose and run it further out the back so when your in and out of cab is not as bad. People have routed to exhaust by weld a bung however it will then pull a vacuum. Is that good is that bad, who knows, conflicting ideas on it all over the webs.
Old Aug 9, 2021 | 07:52 AM
Bitterroot Diesel
Former Vendor
I do not recommend pulling a vacuum on crank case.
Old Aug 14, 2021 | 09:11 AM
Motor Head's Avatar
Motor Head
Just installed the spe internal catch and their reroute kit. Install process was very simple on my 19'. So far I have noticed enough smoke to see, but I do have it dipping out right under the driver door. There is a distinct smell, which is why I am going to extend the hose to vent out near exhaust tip.
Fraalan
Jul 15, 2008 02:00 PM
edub32
36
Jan 14, 2006 05:09 PM
EBSTEVE
Aug 10, 2005 05:32 PM
jcab
May 20, 2005 03:34 PM
