Blower Motor Issue
Old Mar 25, 2021 | 12:44 PM
BassFantasizer's Avatar
BassFantasizer
Blower Motor Issue
Low speed on the A/C blower motor went out.
Testing power at the fan plug with the ignition on and the truck not running, I see 12.25 volts on the top 3 speeds, but only 11 volts on low speed and that voltage continues to drop as I watch the meter.
So the fan seems fine, but I've got a voltage/power issue somewhere up the line?
Old Mar 25, 2021 | 04:07 PM
projectSHO89's Avatar
projectSHO89
What specifically are you working on? Identification is needed in order to look at the correct diagrams.
Are you testing at the blower plug with the blower connected or disconnected? Which wire (harness side)?
Old Mar 26, 2021 | 05:56 PM
BassFantasizer
I wasn't able to test under load as is normally required, so I tested the voltage at the fan as described above.
Proper testing (under load, at the fan with it running) shows 12.66, 9.35, 6.78, and 0 volts for the 4 speeds.
Looks like the problem's in the dash, not the blower motor.
Old Mar 26, 2021 | 07:29 PM
projectSHO89
You still didn't tell us what you are working on....
Old Mar 27, 2021 | 08:02 AM
01__Excursion's Avatar
01__Excursion
Check speed resistor mounted on the blower housing.
Front parts.
Resistor part number shows the same to 2005.
mad1doc
Feb 11, 2017 10:07 PM
tims01
Aug 3, 2015 07:07 AM
EconolineFan
Mar 13, 2012 02:36 PM
Wink1
Jun 12, 2011 10:49 PM
koalamazed
Aerostar
Sep 28, 2004 05:00 PM
