AC Question
Old Mar 25, 2021 | 10:08 AM
off2fsh's Avatar
off2fsh
Trailering
AC Question
Turned the AC on a few days ago, I noticed it starts blowing from the defroster for a bit and then gradually starts blowing out the vents... Selector Switch?????
Also when I accelerate the air blows considerably less???? Vacuum leak maybe?????
Anyone experience this before???
Thanks in Advance
Old Mar 25, 2021 | 10:12 AM
WE3ZS's Avatar
WE3ZS
For safety reasons the system is designed to default to the defrost position if there is a vacuum failure (system controlled by vacuum), so it sounds like you may have a vacuum leak someplace that's affecting the vent selector operation. Is this a 4X4? If so the vacuum switch for the front hubs is a very common failure point for the vacuum system, you can cap off the inlet line to it to test the operation of the HVAC with it out of the loop.
Old Mar 25, 2021 | 10:40 AM
off2fsh's Avatar
off2fsh
Trailering
X is a 2000 4x4 ltd V-10
Old Mar 25, 2021 | 11:25 AM
projectSHO89's Avatar
projectSHO89
Yes. Very common.
Gambill
Jun 12, 2020 04:54 PM
85F350IDI
Sep 6, 2015 11:16 PM
BansheeBoy
Oct 7, 2007 12:46 PM
Jack01
Aug 30, 2005 09:02 PM
bcjim
1983 - 2012 Ranger & B-Series
Apr 21, 2005 11:29 AM
