'21 Leveling Kit Options
Old Mar 24, 2021 | 10:41 PM
Joe T's Avatar
Joe T
Originally Posted by 440 sixpack
1 1/2" sounds good. unless the factory winch is going to be heavy enough to set it down a little ? I doubt it though.
What motor and front springs do you have? You should have optioned the heavy service front springs if you plan to have a winch.
You may consider putting in some 2019 springs 400 or 800 over the base spring.
Old Mar 24, 2021 | 10:53 PM
440 sixpack's Avatar
440 sixpack
Just ordered it today. required the 297 amp alternator but nothing else I don't think.
It's the 6.7 powerjoke engine.
Old Mar 24, 2021 | 11:00 PM
Killer-Bimmer's Avatar
Killer-Bimmer
Originally Posted by Joe T
I only looked into the diesels but I understand camper/snowplow option on a gas f350 gets the max 5990 spring. That would sit around a full inch higher than a diesel with snowplow springs.
I dont think the F250 gas camper/snowplow prep gets those. They would be probably 5200 or 5600.
I think the springs are 4400, 4800, 5200, 5600, 5990.
Ok got it, yeah next time I’m in garage I’m going to measure height as everyone has said the ‘20 & ‘21’s are lower than 19’s but every ‘19 or older I’ve rolled by that is stock I’m higher up front, but so many variables that not a fair comparison. Guess I could roll down the window and yell “what front springs do you have” 😂
Old Apr 5, 2021 | 10:15 PM
440 sixpack
So you can get 2" kits with and without the track bar bracket. is it needed ? I don't mind doing it if I need to but I don't want to do it just for fun.
Buuckster71
16
Dec 7, 2020 08:02 PM
77f2504by4
Oct 28, 2015 09:38 AM
Partime
Oct 23, 2013 01:42 PM
adamysr
Dec 20, 2012 05:54 PM
rtazz17
Sep 21, 2009 02:24 PM
