leveling kit for Highboys?
Old Dec 5, 2020 | 07:58 PM
Buuckster71's Avatar
Buuckster71
Hey guys just curious if there is a leveling kit for the highboys? notice some have a rake to them.
Old Dec 5, 2020 | 08:03 PM
cbrown9064's Avatar
cbrown9064
Caused by bad front springs....replace springs.
Old Dec 5, 2020 | 08:24 PM
ford390gashog's Avatar
ford390gashog
Also check how many springs are in your front pack. People have been known to remove lower springs to soften the ride. These trucks did have a rake from factory and didn't sit level.
Old Dec 6, 2020 | 08:14 AM
Lrrr-RulerOfOmicronP's Avatar
My truck had newer springs all the way around and was only 1.5" higher in the rear.
Old Dec 6, 2020 | 12:32 PM
Buuckster71
D
Is this correct?
Old Dec 6, 2020 | 12:58 PM
cbrown9064's Avatar
cbrown9064
Looks flat and missing springs. Here is mine, General Spring (KC), 9 months installed.
Old Dec 6, 2020 | 01:52 PM
Buuckster71
https://skyjacker.com/shop/suspensio...pring-included
would this possibly level out the truck?
Old Dec 6, 2020 | 02:55 PM
New stock springs will probably give you an 1" of lift. Aftermarket 2" may give you 3" from where you sit now.
I have bought custom made leaf springs from Alcan for 600. That was a few years ago so it might be more now.
If you don't mind making shackles Superduty front leaf springs can be swapped as well and are much cheaper.
Old Dec 6, 2020 | 05:51 PM
cbrown9064's Avatar
cbrown9064
Originally Posted by Lrrr-RulerOfOmicronP
...If you don't mind making shackles Superduty front leaf springs can be swapped as well and are much cheaper.
And the ride will be superior. That is why people do it. Use the search function for "Super Duty Spring Highboy" and you will get ideas.
Old Dec 6, 2020 | 07:30 PM
Buuckster71
Yeah I’ll look into that. Thanks for the info!!
Old Dec 6, 2020 | 08:36 PM
stpackard's Avatar
stpackard
I replaced mine with the HD springs from general spring and I have the flat section going on too. The question is it that they are defective, normal, or needing arched?
Old Dec 6, 2020 | 09:19 PM
This was my highboy with the original style springs. They still had the identification stickers on them. I replaced them with superduty springs. Center of hubs to bump is 27". I thought I had a leaf spring to frame measurement pic but I cannot find it.
Old Dec 6, 2020 | 10:34 PM
Buuckster71
is that measurement before or after the super duty springs?
Old Dec 7, 2020 | 08:23 AM
That is with the original highboy springs. They were replaced by the previous owner so they were fairly new.
Old Dec 7, 2020 | 05:44 PM
Buuckster71
I’m sitting at 25 1/2 from center of hub to bump. So someone must have taking off a spring ?
