Sponsored by: Real Truck
power window conversion
Old Mar 24, 2021 | 09:06 AM
thomham's Avatar
thomham
Cool power window conversion
I am converting my 2016 f250 manual windows to power. I have new door panels, switches, pigtail connectors, etc. I need a wiring diagram for the pigtails. Can anyone help? Thanks
Old Mar 25, 2021 | 04:18 PM
double-s-diesel's Avatar
double-s-diesel
do you need the door harness to body or the inner door stuff
Old Mar 26, 2021 | 08:37 AM
thomham's Avatar
thomham
Have everything I need but dont know what wires connect to what. I,m bypassing the wire harness so the truck doesn.t need to be reflashed. what I need is a schematic for the window and lock circuits. Thanks
Old Mar 26, 2021 | 09:44 AM
double-s-diesel
the windows and locks all go through the bcm
the switches im not sure will handle the load,
, not sure if the wires are present on the truck side of the harness or not, even so it is possible to swap the cab harness I did that on my13 when i put the power seat and console in even swapping the bcm is not bad other then reprogramming the keys.
I have done this before on a 03 and used earlier style switches that i was able to run the load through them
Old Mar 26, 2021 | 09:50 AM
double-s-diesel
locks and reg cab windows
Old Mar 27, 2021 | 09:37 AM
thomham's Avatar
thomham
Thank you. Thats what i needed.
pdqtimetrialer
Jul 7, 2016 04:44 PM
granny_rocket
Electrical Systems/Wiring
May 1, 2013 04:55 PM
dkimmel
Feb 11, 2011 08:27 AM
FordMan1977F250
Dec 7, 2010 08:40 PM
timcos
Appearance & Dress-Up
May 23, 2009 10:27 AM
