what is the part number for the cooling fan blade for a 1972 f250 390?
warmer weather is coming and we got to get the flex fan off and back with the stock blade. thanks for your help.
Depends on which cooling system you have.
Two different choices both 5 blade and 18 1/2" diameter.
Non-A/C trucks took C8TZ8600B. Stamped C8TA-F. Replaced by D9TZ8600A. Which did not take a fan clutch.
With A/C, extra cooling, and super extra cooling trucks took D0TZ8600C. Stamped D0TA-F. No fan clutch listed for a 1970/72 truck.
