Dealer Installed Electronic Locking Dif
Old Mar 22, 2021 | 04:43 PM
blueridgedog's Avatar
blueridgedog
I found a 2021 F350 with all the options I am interested in at a good price...but it lacks the electronic locking rear that I need (I do some surf fishing and spend time on the beach). Can a dealer install this or am I limited to putting in an air locker and pump with an aftermarket kit?
Old Mar 22, 2021 | 04:45 PM
Grass Lake Ron's Avatar
Grass Lake Ron
Yes and yes.
Old Mar 22, 2021 | 05:19 PM
blueridgedog
Originally Posted by Grass Lake Ron
Yes and yes.
Okay, so the dealer I am getting it from can put in the locker...or I can put in a standard air locker of my choice aftermarket. I was concerned with the diesel torque in using an aftermarket locker. A guy just drove off with my 03 Silverado and I am truckless for the first time in decades, so I may just take what I can find on a lot vs ordering what will amount to a 2022...not certain I need the "big screen" and that appears to be the only change.
Old Mar 22, 2021 | 05:27 PM
Grass Lake Ron
If the dealer puts OEM parts in, it's covered under the warranty. I haven't put in an air locker with the 6.7 before, but I bet others have.
Old Mar 22, 2021 | 05:57 PM
Joe T's Avatar
Joe T
If you find a 10.5 sterling rear end truck you can get a tru-track installed pretty easy.
non 4.30 gear 7.3L, non HCTP f250 6.7, and not a f350 6.7, and not a DRW.
Old Mar 22, 2021 | 06:11 PM
4wd6.7L's Avatar
4wd6.7L
Biggest issue I see is price and maybe parts availability. It's going to cost a hell of a lot more than the $390(msrp) that it costs as a factory option.
Old Mar 22, 2021 | 06:12 PM
Peakebrook's Avatar
Peakebrook
ARB does not make an airlocker yet for the 17+ Superdutys.
Old Mar 22, 2021 | 06:15 PM
blueridgedog
Thanks folks. All I can do is ask for a price and see what they say.
Old Mar 22, 2021 | 06:28 PM
JDski's Avatar
JDski
I would go ARB all day long if they have one for the Dana 275. But I know there is not a listing for it yet. With a phone call you may find out when one might be available. Then the price of a factory option at $390 for the e-locker and if available an ARB will be $1200-1400 then add a compressor and mount minimum of $500 -$1000 more and about $1200 to install just the rear set. A little more dealer shopping may save you money. My local dealer does not have a truck without a E-locker on the lot. It depends on the area and the demand for them as for what the dealers stock. I might look a little more.
Old Mar 22, 2021 | 07:27 PM
sky Cowboy's Avatar
sky Cowboy
Maybe a dealer search for trucks within 500 miles, that already have it, sitting on a lot somewhere.
Old Mar 23, 2021 | 05:02 AM
blueridgedog
I have searched the US using zip codes all around. Very few extended cab models, Fewer still with the Camper package/5th wheel and GVWR packages. I think I am down to one!
Old Mar 23, 2021 | 06:04 AM
sstock1's Avatar
sstock1
Dont confuse the price of the factory option with what it is going to cost him to install the elocker. I would opt for the trutrack like other said, that way it will work at speeds greater than 20mph. Plus, I am not fond of it turning into a spool anyway, much rather have limited slip.
Old Mar 23, 2021 | 06:21 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Another option is to get the truck you want, then keep an eye on salvage yards across the country for a wrecked truck with the same axle/gear as your truck, but has the e-locker, and buy the whole axle. Pull the u-bolts and swap the whole axle in. A simple 12v wire to an upfitter switch and you have a working locker.
Old Mar 23, 2021 | 06:55 AM
Pugga's Avatar
Pugga
Keep in mind, the dealer will not likely do anything to the rear end. They'll likely price a whole new rear axle. I had a dealer price a while new drive line because I needed u-joints. They wouldn't get involved in pressing u-joints so their solution is a while new shaft with new joints already installed. The dealer mechanics aren't specialists, they're generalists (not saying that as a bad thing, some are very good). If you're asking the dealer to install the electronic locking rear end, I'd be prepared for a hefty price tag.
Old Mar 23, 2021 | 11:11 AM
frambach's Avatar
frambach
Same here. That's why I went with the F450. I couldn't find the limited slip on a 250/350. I later found there was some which way to order a 350 that made it available.
That being said; I'm super happy with the F450 and it's wide-track front end! I wouldn't change a thing about our truck!
