Cummins swap
Old Mar 22, 2021 | 02:40 PM
Jacobf24's Avatar
Jacobf24
Cummins swap
If I have a 2015 Ford F-150 xlt with 5.0L v8 that is 4 wheel drive and wanting to do a Cummins swap what is better 3.9 or a 5.9 12V, what transmission do I need, or what all do I need to get in order to fit.
Old Mar 22, 2021 | 02:50 PM
ford390gashog's Avatar
ford390gashog
If you have to ask this then you aren't ready for this swap. A measuring tape and taking a look at the CANBUS diagrams would be the first step.
Old Mar 22, 2021 | 03:04 PM
seventyseven250's Avatar
seventyseven250
I'm not an expert, but I think a Cummins swap into a 2015 F150 is a really bad idea.
Old Mar 22, 2021 | 06:16 PM
Kingofwylietx's Avatar
Kingofwylietx
You're a little early for April Fools Day. A person can buy 3/4 ton trucks all day with diesel engines.
No need to go trying to fit one in a truck not designed for it. Anyone serious about doing this wouldn't be asking these questions.
Even so, I'll still answer the main question of what you need to get. The answer to that question is...a 3/4 or 1 ton truck.
Old Mar 22, 2021 | 06:27 PM
muhford's Avatar
muhford
I would skip the 3.9 and 5.9 and go straight for the 8.3.
Old Mar 22, 2021 | 07:07 PM
Siberexpress's Avatar
Siberexpress
If you are going to dream you might want to look at the X15 since you are going to have to rebuild the front end to even put the 5.9 since the F150 front end is not going to support it, Ram front axle is around 4500 pounds with the Come Apart in it
Old Mar 23, 2021 | 07:31 AM
GABAR's Avatar
GABAR
A very ambitious undertaking and if you’re truly serious, totally not worth the expense and effort.
Good luck.
Old Mar 23, 2021 | 08:46 AM
99powerstrokedF250's Avatar
99powerstrokedF250
A lot of time and money.
A donor truck to get the engine, trans, transfer case, and computer/wiring from.
A custom fab shop to help you beef up the front end to support that much weight and make you custom driveshafts and probably a custom front axle, and definitely custom motor/trans mounts.
If I'm not too far off, that custom fab shop is also going to have to modify either your grille or your firewall to shoehorn that big of a motor into this truck.
A Powerstroke swap would be a better candidate, but again, you're going to have a LOT of work to make it fit.
Old Mar 23, 2021 | 10:11 AM
JKBrad's Avatar
JKBrad
A 5 liter Cummins from a Titan would fit. But why bother, just buy a truck with a Cummins in it already if that’s what you want.
Now, if you had a ‘97 or older F250 or F350 then go for it. There are kits to do help make the swap easy.
As for the newer F150s, not even worth trying.
Old Mar 23, 2021 | 10:55 AM
Johnny Paycheck's Avatar
Johnny Paycheck
A 5.0 Cummins is about 900 lbs though. A coke can F150 won’t hold it well. None would, really.
That being said, Cummins does make a 2.8 crate I4 diesel that is about 500 lbs and swap friendlier. No idea what that would entail as far as making it turn your F150’s wheels. OP, that’s for you to take pics and videos of and share with us.
https://overlandcruisersmt.com/produ...l-crate-engine
That’ll be $8200, sir. Cash or charge?
If my ‘03 lasts long enough, I’d sure dream of this when it doesn’t need emissions testing anymore.
Old Mar 23, 2021 | 04:15 PM
Kingofwylietx
Originally Posted by Johnny Paycheck
That being said, Cummins does make a 2.8 crate I4 diesel..............
Unless it is made for the truck, just imagine what a nightmare to try to get the dash working correctly.
The OP is severely misguided or just trolling. My vote is the latter.
Old Mar 23, 2021 | 07:42 PM
brokenleg's Avatar
brokenleg
said it all. If you want a cummins...buy a Ram
Old Mar 23, 2021 | 07:44 PM
brokenleg's Avatar
brokenleg
modify the grille? It would look like that goofy tow truck on cars
Old Mar 24, 2021 | 09:49 AM
CR172's Avatar
CR172
Or Titan..........
Old Mar 24, 2021 | 10:31 AM
99powerstrokedF250
Are you dissing on Mater?
In all seriousness, I don't know if it would need to be modified. I just know that Ford didn't design that engine bay for a straight 6 of any size, so it's going to be wedged under that hood if it'll even fit.
