FORScan “Problem”
Old Mar 22, 2021 | 01:04 PM
OpaMN's Avatar
OpaMN
FORScan “Problem”
Yesterday I connected to my 2017 F350 Platinum (push button start) and backed up all my modules. At the end of that process I decided to disable the Double Honk and enable Secure Idle (Police mode). I changed the settings for both and then clicked the “Write All” button. the accessory mode shut down before the write was completed. The setting changes did not hold in the software. I restarted accessory mode and changed the settings a second time. This time I tried to write the line for disabling Double Honk with the same result. I am guessing that there is a step in this process that I did not complete, but have been unable to find anything specific in the tutorials. FORScan is version 2.8.38 beta. The good thing is I did not ”brick” anything that I can find.
Old Mar 22, 2021 | 01:30 PM
4wd6.7L's Avatar
4wd6.7L
What do you mean by accessory mode?
Old Mar 22, 2021 | 02:02 PM
OpaMN's Avatar
OpaMN
Pressed the start button once without having the Brake pedal depressed.
Old Mar 22, 2021 | 02:07 PM
4wd6.7L's Avatar
4wd6.7L
Hmm, that shouldn't be shutting off on it's own.
Old Mar 22, 2021 | 02:17 PM
OpaMN's Avatar
OpaMN
Again, I am guessing that it is operator error, but it also timed out 2X while I was backing up the module settings.
Old Mar 22, 2021 | 02:24 PM
4wd6.7L's Avatar
4wd6.7L
Unfortunately I don't have any suggestions, I have made changes on several occasions but never have experienced that problem.
I think the double horn honk can be disabled using the plain english method. You could try that and see if it makes a difference.
Old Mar 22, 2021 | 07:26 PM
OpaMN's Avatar
OpaMN
I forgot to mention in my original post that I am using an OBDLink EX scan tool. I am not certain if that makes a difference or not. The backups of the modules went without a hiccup.
Old Mar 23, 2021 | 01:03 PM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
Answered your PM
ZooDad
Old Mar 23, 2021 | 03:15 PM
4wd6.7L's Avatar
4wd6.7L
If you do figure out what the problem was, post up, don't keep it a secret
Old Mar 25, 2021 | 04:55 PM
OpaMN's Avatar
OpaMN
Good news! I attempted the changes a second time today and was successful. The only thing that I can say I did differently was to make certain the OBDLink was firmly seated in the socket. Thanks to 4wd6.7L and ZooDad for the help and encouragement.
More changes to come over the coming weekend!
Old Mar 25, 2021 | 06:07 PM
4wd6.7L's Avatar
4wd6.7L
Good to hear and thanks for the update 👍🏻
Torvvald
Feb 14, 2022 08:20 PM
90pioneer
6.7L Power Stroke Diesel
Jan 3, 2021 09:17 PM
rcorkum4
Dec 30, 2017 07:43 PM
G3angler
2009 - 2014 F150
Nov 12, 2016 03:25 PM
angela_meadors
Mar 10, 2016 02:56 PM
