Bushings?
Old Oct 27, 2003 | 08:33 PM
johnappleseed's Avatar
johnappleseed
Bushings?
I am experiencing a slight problem with my 98 explorer sport. As i roll over roads that are moderately bumpy, i get a chirping sound from the front end. it is really high pitched, and for the most part is only noticeable by me. i am fairly sure that this is not a serious situation, but would definitely like to avoid one. if anyone has any tips i would greatly appreciate it.
Old Oct 27, 2003 | 10:37 PM
c96drumm's Avatar
c96drumm
Welcome to FTE!
Just a shot in the dark, here. Loose hubcap? I've never gotten a sound like that from the suspension, but I guess it's possible.
Old Oct 28, 2003 | 04:26 AM
Opera House Works's Avatar
Opera House Works
Watch TV last night?
They did an expose on the Durango upper ball joint. Some reported a chirping before failure. Pretty rare on later Explorers though the lower ball joints do wear a lot. Just bought the parts to do my 97 lowers this week. Any driveability problems? Could be shock or sway bar bushings.
Old Oct 28, 2003 | 07:05 PM
johnappleseed
Thanks for the replies. The hubcap isn't an issue - since i have custom wheels. And to date i haven't experienced any negative effects, just annoyance. I will check out the ball joints though.
I recently heard through a friend that a mixture of alcohol and graphite will provide lubricant qualities to the bushings, and may solve my problem. Anyone heard of that?
Old Oct 29, 2003 | 07:57 AM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
you can not lube the bushings you will ruin them
but it already sounds like there bad anyway
upper controll arm bushings/balljoint
see it all the time on the 2x4 exp's
make sure you use GOOD replacement parts like MOOG
Old Oct 29, 2003 | 09:21 AM
mrshorty's Avatar
mrshorty
FWIW, I had a "chirp" in the front end of my BII that turned out to be a loose shock mounting bolt. Tightened the bolt and the chirp dissappeared. I guess my point is, before spending a lot of money on parts, get under the front real quick and make sure everything is tight.
Old Oct 29, 2003 | 12:13 PM
FortyFords's Avatar
FortyFords
98 ball joints not greaseable ,common failure is the lower ones ,if you can find a grease needle ,you can get a couple 1000 miles out of them
but as stated replace with moog parts ,their greaseable.
Rich
Old Oct 30, 2003 | 08:04 PM
Opera House Works
Just did my lower ball joints today. What a pain pressing the old ones out. Wouldn't be so bad if you removed the CV axle. Tying stuff out of the way for space isn't easy. I used a Harbor Freight ball joint removal C clamp. Had to turn down my own adaptors to get it to fit. Got the job done but wouldn't recommend this tool to others who are looking for plug-n-play.
ALdieselfan
Jul 17, 2007 08:35 PM
jjlrrw
1997 - 2003 F150
Jun 6, 2007 06:12 AM
fordborn
Kansas Chapter
20
Jun 26, 2005 02:05 AM
ahicks
Missouri Chapter
Feb 17, 2005 07:38 PM
57fordfreak
Jul 11, 2001 09:14 PM
