Steering wheel alignment changes on it's own
Old Jul 22, 2021 | 12:39 PM
redroad's Avatar
redroad
Normally a 4wd F150 has radius arm front suspension, but it being a SC 4wd F150 it should have a leaf spring front suspension. Correct? Since you got the refab box from a generally better parts source, the chances of it being a better quality rebuild are at least... better. BUT NOT always. Is the shimmy just seen in the wheels of felt in the steering wheel?
I am still thinking about what or where the original problem can come from.....Does the new steering shaft you put in have a u joint or a flex joint connection? Is it a Borgeson shaft with the steering damper built in?
I think the problem started with it is a manual steering gear box (Armstrong steering) the shaft gets worn because even with the gearing in a manual steering box it still puts a great deal of stress on the shaft and in the wear areas it gets ridiculously loose. The only solution for me was to weld around the wear areas on the shaft to replace the missing material from the wear and turn it down on a lathe to specs.
Old Jul 22, 2021 | 01:22 PM
1TonBasecamp's Avatar
1TonBasecamp
Originally Posted by Jack Detwiler
Thank you for the help. Sorry for the delay in responding, I was in the process of moving into a new house.
Thanks for the update. Glad the company helped out and you got it sorted!
And congrats and good luck with both the new box, and the new house!
Paul
IrishMike
Nov 29, 2016 05:23 PM
Ronnie Basil Smith
19
Aug 11, 2016 01:01 PM
GeneGregory
Jun 20, 2015 08:36 PM
Sharky146
Sep 6, 2010 09:13 AM
jimkari
Dec 26, 2007 11:42 AM
