Steering wheel
Old Jun 20, 2015 | 02:50 PM
GeneGregory's Avatar
GeneGregory
Steering wheel
The steering wheel in my 79 F-350 4x4 is supposd to be centered going straight down the road like 3 and 9 oclock but it varies between 3 and 9 to as much as 1 and 7 oclock. Is this the steering box or should I be looking for something else worn out ?
Gene
Old Jun 20, 2015 | 03:48 PM
brian1080's Avatar
brian1080
have someone rock the steering wheel back and forth while you look at the steering components. That will show you where the slop is and you can go from there. I'm betting tie rod ends are shot
Old Jun 20, 2015 | 03:51 PM
HIO Silver's Avatar
HIO Silver
Could be a worn or maladjusted steering gear...
Could be a deteriorated rag joint/steering shaft...
Could be a sloppy or loose pitman arm....
Could be worn tie rods....
Could be a worn drag link...
Could be a loose/worn adjusting sleeve....
.....Prolly why it's called a steering "system", right?
Have a helper provide input on the steering wheel while you observe the steering components... everything should move in unison. Start at the steering shaft input to the steering gear while observing the pitman arm... and then the shin bone is connected to the leg bone, the leg bone is connected to the hip bone, et cetera, et cetera, et cetera...
Old Jun 20, 2015 | 06:56 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
4x4 F350 does not have a drag link only F150...got ya lol
All the above and insp the steering shaft u joint, and add up worn ball joint or king pins (D60 front axle), wheel bearing play...and all the rest of the worn components it all adds up to looking like a drunk while driving down the road.
Have you tried to adjust the steering box play? If you have and it is shot, Redhead time. Also insp the adjustable steering link ends. That is the short piece that goes from the pitman arm to the dvrs side spindle.
Old Jun 20, 2015 | 07:30 PM
HIO Silver's Avatar
HIO Silver
Based on the OP's post, I don't think the OP would know one way or the other.
Old Jun 20, 2015 | 07:54 PM
77&79F250's Avatar
77&79F250
Dang that was a below the bumper shot...You know I was just kidding with you right?
Old Jun 20, 2015 | 08:36 PM
HIO Silver's Avatar
HIO Silver
Yessirree.... no prollem.
Ronnie Basil Smith
19
Aug 11, 2016 01:01 PM
Stanislaw
38
Apr 23, 2015 01:48 PM
p.ward7885
Jul 19, 2011 06:08 PM
reamer
Jan 31, 2005 07:25 PM
tab2
Aug 25, 2003 12:57 AM
