PVD wheels
Old Mar 18, 2021 | 06:00 PM
Frank79's Avatar
Frank79
PVD wheels
I’ve read the only Ford recommended cleaner for PVD wheels is soap and water.
what if the brake dust is baked on there?
Ive got some wheel cleaner that has I believe aluminum brightener in it. I used this on my other aluminum wheels with good results. Not sure if this is advisable for the PVD wheels
Old Mar 18, 2021 | 06:11 PM
mtnguy's Avatar
mtnguy
So far, soap and water has cleaned mine just fine.
Old Mar 18, 2021 | 06:17 PM
shawnee1's Avatar
shawnee1
These are not a polished aluminum wheel. The PVD is a very thin vapor deposited coating applied to the aluminum wheel. The coating can be damaged by harsh cleaners. Google "cleaning PVD wheels" and you will find options to soap and water as well as what should be avoided. This will give you a better understanding of the PVD coating.
Old Mar 18, 2021 | 06:27 PM
Killer-Bimmer's Avatar
Killer-Bimmer
Griots standard wheel cleaner has been used for years on very old and sensitive wheels. It’s their least aggressive cleaner, but works well.
https://www.griotsgarage.com/product...ks&from=Search
If you want something heavier for break dust their heavy duty wheel cleaner works great, but more expensive:
Old Mar 18, 2021 | 07:19 PM
BenchDog's Avatar
BenchDog
4wd Low
Ford owner’s manual for 2019 Super Duty, page 369 lists Motorcraft Wheel and Tire Cleaner, ZC-37-A. I have used this product on both 2019 and 2020 F250/F350 King Ranch PVD wheels with no harmful side effects.
Old Mar 18, 2021 | 08:58 PM
f350larry's Avatar
f350larry
You plunge and scrub! And if it's still not clean, you go again, plunge and scrub!
Mark VII
Appearance & Dress-Up
Jan 23, 2023 01:10 PM
stnlycup
2004 - 2008 F150
Apr 16, 2013 08:55 PM
fordboy67
Feb 19, 2010 02:56 PM
SMiller
Sep 27, 2004 10:53 AM
