EGR delete
Old Mar 18, 2021 | 08:13 AM
Simon Espinola's Avatar
Simon Espinola
Question EGR delete
Good morning FTE users
When i bought my truck it had the egr deleted
The egr delete is pretty well done, The cooler deleted, the egr vave gone and closed with a cap, and the big connector that goes under the intake elbow has 2 (or 3) wires cutted
It throws a lot of EGR codes, my PCM was bad but i think that with a fine PCM it will light up the MIL
The SCT programmer could turn off the mil when the egr valve still is in
Wonder if i should buy and install again the egr valve
Much appreciated help
Old Mar 18, 2021 | 12:34 PM
AK4x4's Avatar
AK4x4
Yes, I would recommend hooking up an EGR valve. The computer will be happier and the cooling system (assuming the cooling system is stock) will function as designed. Good luck, Russ
Old Apr 2, 2021 | 02:05 PM
Simon Espinola
Nice, my truck has stock cooling system
Old Apr 3, 2021 | 09:21 AM
F350 1990's Avatar
F350 1990
EGR Deletes are more often than not problems (the EGR provides more benefits than most realize). I recommend sticking with the basic stock setup -- do the regular $10-$15 maintenance (two o-rings and a gasket), clean it (and its installation location) with the correct solvent and don't get cleaner in places that will destroy the valve.
3C3Z-9P455-AB
Also recommend tossing any and all tuners -- the vast majority do more harm than good and they all violate Federal, State laws.
Old Apr 5, 2021 | 03:04 AM
Fuzzpuss's Avatar
Fuzzpuss
You can plug in the EGR valve without mounting it in the intake if you have something to plug/cover the hole.
Also you should get a pigtail and replace the connector that has the cut wires.
Fuzzpuss's Avatar
Fuzzpuss
3C3Z-9P455-AB
Do you care to expound on said EGR benefits?
Old Apr 5, 2021 | 01:54 PM
IABill's Avatar
IABill
Talking
Old Apr 6, 2021 | 12:58 PM
Motohead911's Avatar
Motohead911
[QUOTE=IABill;19816733]
He has been asked many times and never responds. So good luck getting him to answer.
Old Apr 6, 2021 | 08:20 PM
Fuzzpuss's Avatar
Fuzzpuss
Sounds like no benefits to me.
Old Apr 11, 2021 | 08:34 AM
F350 1990's Avatar
F350 1990
Cylinder head longevity (Powerstroke heads are notorious for cracks) , exhaust valve life, and overall improved engine life compliments of reduced cylinder temps plus you're following Federal, State, and local laws.
Technician aid:
https://technician.academy/advantage...recirculation/
Old Apr 11, 2021 | 08:37 AM
F350 1990's Avatar
F350 1990
[QUOTE=Motohead911;19818467]
Hey some of us work for a living - don't spend all day here. I do answer / help people so why don't you put down the popcorn, take your silly-nonsense opinions elsewhere.
Old Apr 11, 2021 | 12:14 PM
TooManyToys.'s Avatar
TooManyToys.
Technician aid:
I thought the EGR system strategy is active mainly during partial engine loads and at low and medium engine speed areas, where oxygen is in excess. In the high engine load (torque), the EGR system is deactivated, the cylinders being filled only with air, during the hottest combustion temperatures.
The cracking at the valve seats has more to do with the induction hardening stresses left behind, IMO.
Old Apr 11, 2021 | 10:27 PM
Motohead911
Or get new heads with hardened valves and seats.
Old Apr 12, 2021 | 07:44 AM
TooManyToys.
The issue with the retrofits is you still have the stress in the metal surrounding the seats. I would have preferred seat inserts from the start, without the induction hardening.
Old Apr 12, 2021 | 09:06 AM
IABill's Avatar
IABill
Quote:
Well no answer yet but this:
