Sponsored by: Real Truck
OBD port issue
Old Mar 16, 2021 | 02:19 PM
bigred66's Avatar
bigred66
OBD port issue
Hi have a 2006 F250. I have an Edge Insight plugged into the OBD port. Everything works on the display except the EGT reading. If I push up on the cord that plugs into the OBD port the EGT will read. I've had to tie a zip tie around the cord to keep it super tight in order to give the EGT readings. The strange thing is that if I don't have the zip tie holding it tight, all other readings show just fine. I can even plug in programmers code readers and the OBD port seems fine. Why would only the EGT reading have issues? Should I replace the OBD Port? It's a pain to keep using zip ties and now its getting to the point where the zip ties are having issues keeping it tight enough.
KeysMako192
Mar 26, 2024 11:46 AM
RainHellFromAbove
Computer Chips & Tuners
Nov 26, 2012 10:03 AM
pnj442
Dec 29, 2010 05:19 PM
thebiga
2004 - 2008 F150
Dec 4, 2006 03:00 PM
707ford
2004 - 2008 F150
May 27, 2006 01:44 AM
