What keeps the front coils from coming out on their own? I realize the weight of the truck keeps them in, but what if I where to raise the front end off the ground with a hoist, or an off road situation, etc.? I ask this because when I installed my 2.5" leveling kit (Ready Lift), the instructions simply said to raise the front end or lower the axle until the coils fell out. The only thing I can see is the sway bar and shocks, they might hold for a bit, but still. On my 1975 1/2 ton 4x4, there is an "L" bracket bolted to the top, and a metal disk plate and bolt at the bottom. But on my '17 F350, no hardware at all..........what am I missing?
From what I can tell it's like you said, the sway bar and shocks that are the limiting factors. So I suppose if you decided to disconnect your sway bar, and had a shock break, also while doing some extreme off roading, it could be a problem.
Thats kind of scary, imagine a roll over accident at highway speed and the coils get ejected.
Thats if the shocks and sway bar break, and in the case of a high speed roll over, you'll have far bigger things to worry about. It will be a yard sale regardless. If it keeps you up at night you could have limit straps installed.
I haven't looked closely at the Ram trucks, but I think its the same.
The bump stops prevent rolling travel of the frame and cab. Without bump stops, it's possible (but unlikely) that you could flex the suspension enough to unseat a coil spring. Unless you removed your front sway bar, removed the top mounting nuts from your shocks, AND removed the bump stops, it would take an ungodly amount of twisting and rolling to eject a coil spring. You likely wouldn't survive that wreck to know any better.
I did jack it up by the frame, as the instructions said..........and the coils fell out. (Thus prompting my question).
Thats a change from your original post. You originally acknowledged that the shock and sway bar keep the coil from falling out. Now you are saying with sway bar and shocks installed your springs fell out?
The Ready Lift instructions do not say to simple lift the truck by the frame till the coils fall out. Like all the rest of the lift kit instructions they tell you to undo the brake line mounts, undo the sway bar end links (from the frame in this case) and remove the shock.
I dont think the sway bar helps limit pinion arm extension to the point that the shocks dont fall out.....the sway bar is in a bushing that allows it to rotate to follow the axle. the shocks definitely limit pinion arm extension. the last time I installed a level kit...I had to disconnect the shocks and remove a brake hose clamp....then jack up the truck and the spring could be pulled right out.
Of course I had to remove the sway bar mounts and shock mounts, didn't feel I had to go into full detail. And I did not acknowledge the sway bar and shocks limited travel,.....I assumed this and came here looking for verification.
And you were told, several times and still you gave the impression that simply jacking up the frame allowed the coils to fall out. Unless I misunderstood your response in post #8.
And for reference,a qoute from your op, "I ask this because when I installed my 2.5" leveling kit (Ready Lift), the instructions simply said to raise the front end or lower the axle until the coils fell out. The only thing I can see is the sway bar and shocks, they might hold for a bit, but still."
The spring is captured by the shock's travel. Jack up the truck by the frame, you'll see that the coil doesn't just fall out.
The spring is captured by the shock's travel. You didn't just jack up the frame, you unbolted the shock mounts which is what allowed the coil to fall out.. That's not going to happen just rolling down the road. Even if you break the shock in a catastrophic roll over, if the axle drops far enough to let the spring out, it's not coming out under pressure, it will come loose because the tension has been released by the shock no longer being able to limit the axle droop. As stated above, if that happens, that coil coming loose is not your primary concern. There was a news story a couple weeks ago where some guy ran his Super Duty off a highway overpass, thing was air born for a while, coils stayed in place.
