Power steering problems
Old Mar 14, 2021 | 05:52 PM
uuuhCharlie's Avatar
uuuhCharlie
I have an 81 f250 with the 400 in it and the power steering recently went out so I decided to replace the pump and I must’ve not caught the fan and new pump barely turning while it was being turned. Anyone know what this is and how to fix it?
Old Mar 14, 2021 | 06:12 PM
matthewq4b's Avatar
matthewq4b
First off the PS pulley is not fully installeld/seated. That needs to be fixed first.
And second, it looks like the belt is not tight enough.
Old Mar 14, 2021 | 06:14 PM
uuuhCharlie
okay I’ll get that pulley all the way on and then how do I go about tightening the belt if you know?
Old Mar 14, 2021 | 06:49 PM
matthewq4b's Avatar
matthewq4b
there are 3 nuts on top of the bracket losen those then tighten the one on the side till belt is tight and then tighten up the 3 nuts on top.
Old Mar 14, 2021 | 06:51 PM
uuuhCharlie
okay I will do that tomorrow and let you know how it went also how would a loose belt almost completely stop the fan?
Old Mar 14, 2021 | 07:45 PM
matthewq4b's Avatar
matthewq4b
The belt drives the fan also...
Old Mar 15, 2021 | 02:36 AM
Ken Blythen's Avatar
Ken Blythen
Yes, your pulley does need to be positioned further back.
But the main issue is that the belt is the wrong section for the pulleys (or is badly worn)......so it's bottoming in the groove & slipping as a result.
There must be clearance under the belt so it wedges into the groove & drives positively; it can't transmit power effectively if it contacts the bottom of the groove......and at times, a fan sucks up quite a few hp.
Oakham Ford
Dec 15, 2020 04:29 PM
02Ford150
1997 - 2003 F150
Apr 11, 2020 01:03 AM
400 .040over
Nov 22, 2011 06:48 PM
