Flatbed wood thickness?
Old Mar 14, 2021 | 03:49 PM
Beto Gray's Avatar
Beto Gray
Looking at building a bed, and am wondering what thickness wood to use?
5/4" deck board
OR
standered 2x6?
thanks in advance!
Old Mar 14, 2021 | 09:15 PM
bobr123's Avatar
bobr123
5/4" deck board
OR
standered 2x6?
thanks in advance!
I'd suggest 3/4" ply. The boards you mentioned are heavier than you need. Yes, utility trailers are decked with "2-by" boards, but people park cars and other very heavy equipment on utility trailers.
3/4" ply is quite strong due to the laminated construction. Heck, your house probably has 3/8" ply (or OSB) on the roof with the supports 24" OC. Is the 3/8" strong enough to stack lumber, tools, etc on it? Absolutely. Double the 3/8" and you're at 3/4". It would make for a cheap and light deck that is stronger than the factory bed.
I would suggest running it through a table saw to cut into separate "boards" 6" (or whatever is desired) width. Space them 1/4" apart. This would give it a better look than the solid deck. Before mounting, fill any voids and paint, or stain, or (I've done this) epoxy with a top coat of roll on bed liner.
Old Mar 14, 2021 | 10:43 PM
ford390gashog's Avatar
ford390gashog
5/4" deck board
OR
standered 2x6?
thanks in advance!
I use 5/4 aptitong for my decks. It's easy to get and very durable. https://www.trailerdecking.com/Apito...king-54x8-3810
Old Mar 14, 2021 | 10:44 PM
bleeds blue's Avatar
bleeds blue
Beto, all my flatbed trailers have all had 2X6 boards on the deck. I don't know where you are located, but here in Utah, lumber is so expensive right now it may be cheaper to make the deck out of aluminum!
Old Mar 14, 2021 | 10:47 PM
Beto Gray's Avatar
Beto Gray
@bleeds blue Central IL here. Lumber here is pretty expensive too, but aluminum is expensive to... and I don't have a way to weld aluminum, and the shops are charging $75 an hour to weld aluminum. So I'm not sure it would be much cheaper.
Old Mar 15, 2021 | 05:49 PM
Mlarv's Avatar
Mlarv
What are you going to haul? How big of a trailer? I have seen everything from #2 white oak to treated 2X6 for decks. 3/4 treated ply might work if you are not hauling anything to heavy. If it is an open deck trailer I would not use 3/4 ply just because water will pool on it and cause mold (think deck on a house). Support under the deck material will dictate what the top should be.
My enclosed car hauler has 3/4 ply my old utility trailer had 2x6 white oak.
Roof decks on most houses are 1/2 inch on 16 inch centers or 5/8th on 2 foot centers by code.
Old Mar 15, 2021 | 07:02 PM
Beto Gray's Avatar
Beto Gray
@Mlarv this is a flat bed for my truck
It'll haul all sorta stuff, hay, wood, tools, atvs etc.....
Old Mar 16, 2021 | 12:19 PM
Mlarv's Avatar
Mlarv
I see. I think I would still use 2X treated butted tight to each other. It will take more abuse than ply. If you can find rough sawn white oak that would be the best thing to use.
Old Mar 16, 2021 | 12:32 PM
ford390gashog
That's why I suggested aptitong, it's the industry norm for heavy use beds. It exceeds white oak in strength and durability and is runner up to purple heart which is too dangerous for most to consider working with..
https://www.trailerdecking.com/ProductID3811
Old Mar 16, 2021 | 01:04 PM
Mlarv's Avatar
Mlarv
Thats some pretty impressive wood. The cost I saw on it wasn't that bad for what you are getting.
Old Mar 16, 2021 | 01:11 PM
ford390gashog
Often the cost is much lower if you have access to heavy truck trailer shops. There is also a opportunity to buy it used as its often recovered from trailer floors. It's also weather and mildew resistant. I paid 2.00 a LF for mine as rough sawn 5/4 7" wide. I totally cheated after install and used a floor sander to bring all the boards down flat. Anchored with stainless deck screws and finished with tung oil I had.
Old Mar 19, 2021 | 02:29 PM
Toyman's Avatar
Toyman
I decked my gooseneck trailer with 2x southern yellow pine. most trailer companies are using it, it's less money than oak but very dense for a pine. It is more of a hardwood than the typical pine we all know for construction lumber.
ghalperin
Feb 6, 2023 05:17 PM
Red60
Nov 24, 2020 06:28 AM
Arroyoman
20
Jun 2, 2008 07:22 PM
johnmcarguy
Dec 30, 2007 11:38 AM
Franklin2
Aug 26, 2002 10:05 PM
