brown smoke???
Old Oct 27, 2003 | 04:27 PM
coolmint94's Avatar
coolmint94
brown smoke???
Ok, my friend bought a rebuilt 390 about a year ago. Well he hasnt had any problems with it till today. This morning he said he had brown smoke coming out the tail pipe. He was a little worried so he shut it off and left it. He was wondering if i knew if anything was worng. I of course didnt so I came here. Anyone know if there is a problem??
Also, he was wondering what he would have to do to the engine to make it a 429. I dont know if they are the same block or if it would have to be a 428. Well what ever it is, let me know so I can pass on the info. Thanks for the help.
--Dan
Old Oct 27, 2003 | 06:11 PM
Ratsmoker's Avatar
Ratsmoker
The 429 is a a completely different animal. Some 390s will bore out to a 428 and all will accept a 428 crank if you can find one. Brown Smoke?? You got me on that one. Somebody mighta put some manure in the gas tank? Seriously, what does it smell like?
Old Oct 29, 2003 | 04:30 PM
coolmint94's Avatar
coolmint94
OK, so if he were to make it a 428 what would he need? And how much will it cost? He is still in highschool and has a parttime job but spends all his money on his truck so he dont care how much it will be. He justs needs to know what he needs.
Old Oct 29, 2003 | 05:11 PM
Mike G's Avatar
Mike G
First you would need to determine if the 390 can accept a bore to the 428 specs (sonic mapping by the machine shop will do). After that, crank/rods/pistons and a 428 flywheel/flexplate (cash as well ).
I would start by pulling the plugs and see if there is any discoloration on them that would indicate a problem. Usually we see white or blue smoke (and plenty of it with mine) but the brown is a mystery.
--MG
Old Oct 30, 2003 | 12:59 AM
BB's Avatar
BB
I've seen brown smoke before and wondered what it was. Have heard a few reasons like bad gas, additives in the gas, the gas formulation, running too lean, blowing the carbon out, blowing the exhaust out (extension of the carbon one) and pinging/detonation. Thinking about it a little more, I've seen it when someone's getting on it.
I have a theory, since this happened to your friend who is also talking about a 429, maybe he was getting on that 390 a little hard?
Barry
Old Oct 30, 2003 | 03:03 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Rust? From inside the manifolds?
Old Oct 30, 2003 | 03:54 PM
Comegetsome's Avatar
Comegetsome
Certain lead substitutes or anti-knock gas additives can have a redish brown colour when burned, but it's unusual to actually notice it.
Old Oct 30, 2003 | 04:01 PM
krewat's Avatar
krewat
That's what I was thinking at first, but it's usually a brown buildup inside the exhaust not "smoke".
Old Nov 2, 2003 | 05:19 PM
Dealford's Avatar
Dealford
--MG
. I believe that you will find that replacement rods are not needed.
The 390 has a rod length of 6.488 as does the 410/428. The preferred rod of that length starts with "C7...", sorry I don't have the correct casting # handy.
Old Nov 2, 2003 | 07:31 PM
Ratsmoker's Avatar
Ratsmoker
That would be C7AE-B and you are correct. The only difference between the CJ rod and the 390 rod is bolt size. I like the smaller bolt rod with ARP bolts.
Old Nov 3, 2003 | 09:31 AM
Mike G's Avatar
Mike G
Sorry about that little error, I feel shame...
Old Nov 3, 2003 | 08:15 PM
ZRX61's Avatar
ZRX61
Having been a Kawasaki mech since the 70's I may be able to throw some light on this....
In the original Z1 manuals there was a bit about trouble shooting different color smoke
Blue: Oil
Black: Fuel
Brown: One of the main jets has fallen out
(Yes, thats really what it said, LOL!)
Old Nov 3, 2003 | 08:48 PM
muddmarine's Avatar
muddmarine
Simple fix maybe, run it up again. Pay attention to the water temp and oil pressure. You said, it was rebuilt a year ago. What Im wondering, when it was rebuilt....it was the typical smoker engine.
Now its hittin and burning out the junk from the left over VOC's from the exhust system from the preveiuous engine, exhuast.
Let the thermistat break and settle out, shut down and look at the plugs. Pay attention to the gas ring on the porcelin, the lower the better, for ideling.
Then drive it, a hard run, plugs will tell the story.....Motor Craft 45's will have the gas ring about mid part of the plug.
Jables4life
May 11, 2016 05:42 PM
Meagan Izquierdo
Feb 25, 2016 10:43 AM
LOVEMYLABXS
Jul 26, 2014 02:06 PM
Javve
2004 - 2008 F150
Apr 29, 2013 07:42 AM
hink10
Sep 16, 2012 01:13 AM
