Lifting the 2WD Excursion
Old Mar 12, 2021 | 09:59 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
So i have a plan i want to run past some of you guys....
So, i was looking at a 2 stage lift process, larger tires, combined with a suspension lift to achieve the desired results.
First up, currently i have 245/65/16 tires and wheels, the plan is to go to 285/75/16 (+2 inches) OR if i can find some good 18 inch wheels, 285/75/18 (+4 inches)
Secondly, this kit, which is also 2.5inch front, 2 inch back.
https://www.ebay.com/itm/2-5-Front-2....c100047.m2108
Am i in for any pitfalls, problems, etc, if i were to get this kit and have it installed? Depending on wheels/tires, if im working this out properly, i will end up with 4 or 6 inches of lift.
Old Mar 13, 2021 | 09:43 AM
WE3ZS's Avatar
WE3ZS
I didn't double check those tire measurements, but if they are in fact 2" different in height the new taller tires would only add 1" to the mix, the second inch would be above the axle centerline, so no extra height from that inch.
Old Mar 13, 2021 | 02:56 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Old Mar 14, 2021 | 05:07 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
bump, anyone know if this will all at least work ok, and not give me any pinion angle or suspension issues?
brangus82
Appearance & Dress-Up
Oct 14, 2014 09:00 PM
VONxRUBENxLA
Sep 19, 2011 08:19 PM
chevyassasin
Jan 21, 2010 05:14 PM
vans333333
1997 - 2003 F150
Apr 8, 2007 07:29 AM
Country4.2
1997 - 2003 F150
Jun 5, 2006 09:16 AM
