Excursion 7.3 compatible frames
Old Mar 11, 2021 | 07:16 PM
Joseph Barrett's Avatar
Joseph Barrett
6th Gear
I have a low mileage (135K) 2000 7.3 Excursion that has a serious case of body rot. I am looking at finding a donor vehicle that I would transplant my 7.3 into and finding alot of cheap clean V10/6.0 rigs. Is a NON 7.3 Excursion a possible option? thanks
Old Mar 11, 2021 | 08:33 PM
MasterX's Avatar
MasterX
MUST GO FASTER!!!!
Ill let someone else answer definitively but i believe as long as you are willing to swap over harness, electronics, etc, then anything should work. But finding a vehicle that is already a 7.3 would be less work. Finding a 7.3 Ex with a blown motor would be the holy grail for you.
Old Mar 12, 2021 | 04:11 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
MasterX is correct. Swap over all the harnesses and you are good.
Old Mar 12, 2021 | 08:03 AM
rockhounds4x4's Avatar
rockhounds4x4
6.0 would be easier, if you buy a gasser then you are swapping complete fuel systems also, including the tank lines everything
gardnesd
Apr 26, 2016 03:35 PM
officer131
Dec 12, 2012 07:16 AM
onetankerdad
Nov 23, 2010 07:51 PM
yardboy
Jan 29, 2008 09:29 AM
jmunkie13
Jan 7, 2008 08:41 AM
