“THEFT” light in dash
Old Mar 9, 2021 | 08:15 PM
Rainmaker1's Avatar
Rainmaker1
I just had a new gear shift lever installed yesterday. Tonight I was sitting in the truck eating fast food with the engine off, key in the ignition, and the THEFT light in the dash is flashing about every 2-1/2 seconds. I never noticed this before. Is it supposed to do this?
Old Mar 10, 2021 | 06:36 AM
projectSHO89's Avatar
projectSHO89
Yes, that is what it is supposed to do.
See owner's manual for display and indicator information.
Old Mar 10, 2021 | 10:12 AM
2002Ex's Avatar
2002Ex
Theft Indicator
The instrument cluster provides the THEFT indicator with power. The theft indicator is hardwired to the PATS module and will flash when the PATS system is activated.
All elements of the PATS must be functional before the engine is allowed to start. If any of the components are not working correctly, the vehicle will not start. PATS uses a THEFT indicator. This indicator will prove out for three seconds when the ignition switch is turned to RUN or START under normal operation. If there is a PATS concern, this indicator will either flash rapidly or glow steadily when the ignition is turned to RUN or START. PATS also flashes the theft indicator every two seconds at ignition OFF to act as a visual theft deterrent.
fordka
Ford Truck Parts for Sale
Mar 2, 2017 05:10 AM
NewEnglander
1978 - 1996 Big Bronco
Dec 10, 2011 12:01 PM
restomod
Mar 14, 2008 11:01 PM
jcs1966
Jun 1, 2005 08:43 AM
