EEC-IV board schematic
Old Mar 8, 2021 | 10:25 PM
maseman__46's Avatar
maseman__46
Howdy! This is my first post, and I'm kind of in a hurry, so let me apologize if I screw up. I am unable to send private messages, so I figured this was the best way. As the title states, I am looking for a pcb diagram for the EEV-IV pictured below (It's a 1990 unit with an 87 engine) After countless hours of looking, trying to cross reference the part number on the component and who knows how many datasheets. I came across a diagram posted by subford that is what I need. However, I am unsure if it applies to the unit I have. I'm hoping he reads this or someone else can help me identify what circuit it's for. I've hit a dead end with my meter as I can't seem to make heads or tails of it. Again, Im sorry if I screwed up, thank you all!
Old Mar 9, 2021 | 04:49 PM
Franklin2's Avatar
Franklin2
I thought we figured out in the other post it was the ISC or idle control circuit? Pin 21? The thing you are holding in your hand is TIP121 a transistor?
Here's a data sheet. https://www.onsemi.com/pdf/datasheet/tip120-d.pdf
Old Mar 9, 2021 | 07:19 PM
maseman__46
I spent several hours reading and tracing that diagram with my meter. That diagram isn't the correct one unfortunately, and I am at a complete loss once again
Old Mar 10, 2021 | 06:26 AM
maseman__46
Turns out I completely missed a very obvious trace... I was only checking from the cathode side of the diode. I believe it is the 3-4 shift solenoid. The diagram above is only for a manual transmission, but I would think it's the same as the others. In case anyone else makes a bonehead mistake like I did 😂
Aiden200
Jan 3, 2021 05:20 AM
1986F150six
Mar 13, 2019 02:20 PM
r8er4ever
May 30, 2015 06:08 PM
Jake in PA
Mar 26, 2013 07:34 PM
pacrewchief
Dec 11, 2011 11:57 PM
