Wheel options for 92 2WD F250 8 lug
Hi folks.
Picking up a pretty nice F250 in an hour or two and I am curious what options are out there for wheels. Itls pretty grandpa fresh right now and I'd like to do something different with some more aggressive tires. Thanks for any help you can offer. If I had a "dream wheel" it would be a slotted mag
I run American Racing AR62, obviously you can get Alcoas for a factory option kind of look but pretty much any 16" wheel in your lug pattern without a crazy offset should work. Are you keeping your stock suspension? I would assume so since it is a 2wd? I believe you can run 235/85/16's, and 265's on a stock suspension. I think you can fit a 285/75/16 if you adjust the front bumper. Can I get your hubcaps from you if you are ditching these wheels?
Here is what I have on mine. B&B Wheels. About 500 bucks. On Cooper tires 285/35/16 The only issue I had was the rear wheels. The center caps would not fit because of the extension of the hub on our 2WD. Three bolts hold the center cap on and I had to cut three small pieces of pipe painted them black and bought three longer bolts and it now fits great. Because of the knuckle on the passenger side, raising the truck even 2" with a spacer made proper camber adjustment impossible, so be aware if you go with bigger tires. . I took the spacers off.
Also 1996F250 I have a set of the hub caps if Fairlane446 doesn't want to sell his. You can PM me if interested. Sandy
RollinHi95
07-09-2006 07:54 AM
