Did I Do This Right ?
Old Mar 7, 2021 | 09:00 PM
blake in spokane's Avatar
blake in spokane
I welded in a CPP mustang kit, the directions said to mount the cross member a certain distance back - then mount the spring towers another 7/8 back for power steering castor. Is this right?
Old Mar 8, 2021 | 05:10 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
I am not sure without seeing the instructions myself but ain't it kinda the wrong time to ask if you already welded it in?
Old Mar 8, 2021 | 07:08 PM
Waygonner's Avatar
Waygonner
I can’t tell if It is in the perfect spot relative to the crossmember but you are correct in having the longer side of the hat towards the front. It helps stabilize things when braking and steering.
Old Mar 8, 2021 | 10:33 PM
blake in spokane
The longer side is in back for pos caster
Old Mar 8, 2021 | 11:00 PM
Waygonner's Avatar
Waygonner
Is the part I circled towards the front? It looks that way based on your steering rack location. That tall part should be on the front side to help with anti dive. At least that was what TCI and Heidts showed in their instructions.
Old Mar 9, 2021 | 07:34 AM
rdemilt's Avatar
rdemilt
You are good, with the top hats set back as you have them it already gives you some positive caster you'll be looking for. If I remember their instructions say the can be mounted straight centered, 3/8" back for manual steering and up to 7/8"' back for power steering. I called and talked to the tech department for reassurance before welding mine in.
Old Mar 9, 2021 | 06:39 PM
Waygonner's Avatar
Waygonner
I misread the question and I agree with previous post. Sorry for the confusion!
BleackBeast
Sep 17, 2017 02:06 AM
66 twin i
Dec 22, 2012 12:05 PM
A/Ox4
Jul 19, 2011 10:45 AM
hotrodbob51
Feb 15, 2011 06:51 AM
forumsearcher
Nov 30, 2008 05:56 PM
