airbag light code 52
Old Mar 7, 2021 | 09:00 PM
ethanmom's Avatar
ethanmom
how to clear it
Old Mar 8, 2021 | 07:57 AM
Mike4393's Avatar
Mike4393
Originally Posted by ethanmom
how to clear it
Hello
Code 52 just means that the battery voltage to the airbag curcit has been interupted. If it flashs code 12 this is a hard fault and you will probably find the fuse blown. First check all the fuses,
Old Mar 8, 2021 | 11:24 AM
projectSHO89's Avatar
projectSHO89
how to clear it
You need to explicitly identify what you are working on.
Lamp Flash Codes have varied over the years, depending on the model, and the code that means something on one model means something else on a different model or year.
Old Mar 8, 2021 | 01:02 PM
Hamfisted's Avatar
Hamfisted
I would suggest buying the Blue Driver OBD2 adapter and downloading their software to you phone or iPad . It reads everything and every module that's readable in your Expy and can easily reset any of the modules to clear DTC codes and your system warning light.
Blue Driver Scanner Application
Blue Driver OBD2 Adapter on Amazon Blue Driver OBD2 Adapter on Amazon
RigCity
Dec 29, 2020 07:37 AM
Newnavowner
2009 - 2014 F150
Nov 23, 2020 02:12 PM
emilbolboaca
1983 - 2012 Ranger & B-Series
Nov 28, 2006 08:53 PM
bottles88
Nov 10, 2004 06:46 PM
