Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
79 F600 VIN decode
Old Mar 6, 2021 | 08:07 PM
BrightlimeF100's Avatar
BrightlimeF100
79 F600 VIN decode
I’m looking at getting a 1979 F600 and I would like to know the original specs and engine/trans/rear axle info.
From what I’ve found it has a 370 and I know it has a 2 speed rear end just don’t know what it’s rating is.
I have a picture of the VIN tag from the door below
[img]blob:https://www.ford-trucks.com/1369538b-34a5-4444-84ad-bdaf14fe7901[/img]
Old Mar 6, 2021 | 10:01 PM
85e150's Avatar
85e150
Welcome to FTE!
F60 = F600 2WD gas
C = 370 2V
V = Kentucky Truck Plant
FC1057 = 1979 numerical sequence
158 = 158 inch wheelbase
No color code, painted non-standard color
F607 = 1979 F600 gas, 2WD, 19,700lbs GVWR
AA8 = Standard regular cab. I don't have the full decode for upholstery, seat type etc.
A = New Process model 435 four speed transmission
F3 = Eaton model 15201 two speed rear axle, 15,000lbs capacity, 6.33/8.81 ratios
No front axle code.
19700 = 19,700lbs GVWR
525325
52 = Dallas District Code
5325 Special Order Number.
As to the 370, I have never been able to find the published HP/TQ for those or the 429 truck engine. With the two speed, it will do ok but you will hit a wall about 60 to 65 mph if it's running right.
Old Mar 7, 2021 | 12:26 AM
BrightlimeF100
Originally Posted by 85e150
Welcome to FTE!
F60 = F600 2WD gas
C = 370 2V
No front axle code.
525325
Awesome thank you this is everything I was needing.
'77F250C
1978 - 1996 Big Bronco
Oct 5, 2020 10:44 AM
Jeffrey Robertson
Aug 15, 2017 01:07 PM
tmose1963
Aug 27, 2016 03:06 PM
c.l.nye
Jan 2, 2010 06:04 PM
juchertf100
Jan 19, 2007 12:40 AM
