2013 E350 Third Tailight LED Replacement
Old Mar 6, 2021 | 05:59 PM
Triton2010's Avatar
Triton2010
Having a leak on my third brake light ( like others) and will be fixing with a more permanent solution of butyl tape (2) thicknesses
making the assembly really hard to take off.
While I was doing this and it is a 2013, I thought I should get new halogen (original) bulbs and replace them before assembling it.
But it seems like an LED replacement bulb would be best with a much longer life.
Has anyone done this?
Old Apr 4, 2021 | 05:36 PM
Jon Finsness's Avatar
Jon Finsness
YES LED IS THE WAY TO GO
My 95 E150 lamp was replaced twice, finally, my son who does auto glass gave me a tube of his butyl sealant (like caulk), not leaked since. Just got a 14 E250, bought a replacement lamp assy and fixed it right away.
Old Apr 6, 2021 | 03:53 PM
MoeDaMaster's Avatar
MoeDaMaster
Any bulb recommendations? I'm asking because there are LED bulbs with a wide range of designs and number of LEDs.
Are there aftermarket 3rd brake light units just like with the taillights?
Best,
Moe
Old Apr 6, 2021 | 07:27 PM
blageurt's Avatar
blageurt
I would just go stock..and use 100% Silicone ...Bytle is too hard core...I would retain the stock gaskets and just add a small bead of Silicone on the outside edge ..apply Di- electric grease on the connectors ...maybe change ( Heat shrink and solder ) them and you should be OK....I have done it several times...My Van is a Roofing Truck and **** gets smashed all the time...JMHO.... I also went to junkyards ALOT and pulled out several Intact units..just for parts....I still have 3 or 4 complete assemblies ...If you need one let me know I have at least 3 maybe 4 ....But you can Pull one yourself no problem you need a #2 Philips and a 10 MM IIRC ..... regardless Good Luck
vwfreak
18
Aug 4, 2017 09:09 PM
bneafus
Jan 24, 2012 12:33 PM
Larry NCKS
Mar 26, 2011 04:39 AM
FL_BWAB
May 2, 2007 02:44 PM
JoeBoost
Dec 20, 2003 03:26 PM
