Bulb Replacement
Old May 2, 2007 | 09:36 AM
FL_BWAB's Avatar
FL_BWAB
Bulb Replacement
I Am Haveing A Hard Time Repaceing The Light Bulbs In My Ford F-350
Please Help
Old May 2, 2007 | 10:10 AM
MLCinNCTX's Avatar
MLCinNCTX
I'll bite, which ones are you having a hard time with?
Old May 2, 2007 | 10:22 AM
FL_BWAB's Avatar
FL_BWAB
I Can Unplug The Light I Just Cant Get The Bulb Out To Replace It
Old May 2, 2007 | 10:30 AM
Suber's Avatar
Suber
Again, WHICH ONE?
Old May 2, 2007 | 10:34 AM
FL_BWAB's Avatar
FL_BWAB
O Yea No Kidding Lets Try This Again I Am Trying To Replace The Head Lights And I Cant Get The Bulbs Out To Replace Them
Old May 2, 2007 | 01:53 PM
Tofudi's Avatar
Tofudi
I take shoe lace and tied a noose. Put it around the back as far forward as I could and then pull ! ! Good-luck.
Old May 2, 2007 | 02:44 PM
14psd's Avatar
14psd
If they haven't been replaced in a while the rubber oring can get stuck as you have found out. Make sure the lite is unplugged (careful the clip can and will break easily!) and then turn that ring locking thing til it comes off. Now comes the hard part. I have had to single-man grip it and give it a tug backwards (out). Before you put the new one in I like to put some silicone or teflon on a towel and rub it on just the o ring and the next time you have to replace a bulb it comes out MUCH easier. Oh yeah DON'T get any on the bulb itself or oil from your hand it will cause the bulb to blow right away if you didn't know that already.
