Electrical problem
Old Mar 5, 2021 | 07:58 PM
Jluna126's Avatar
Jluna126
Electrical problem
Does anyone have any idea why my truck refuses to start? I have an 86 f350 with the 460. I just replaced the alternator and the starter. It has a new battery but I have to jump it to get it to start. It turns over and then makes a grinding noise and it gets weaker and weaker. I jumped the solenoid and it clicks like it's supposed to. I've checked all the wires and they all look good.
Old Mar 5, 2021 | 08:39 PM
kr98664's Avatar
kr98664
Before changing any more parts, pour yourself some coffee and peruse this. It was written specifically for your situation:
https://www.ford-trucks.com/forums/1...w-starter.html
Make sure the battery is fully charged before any testing. Most new batteries are not fully charged at the time of sale. I suggest hooking up an automatic charger overnight, something with at least a ten amp output. A trickle charger won't cut it.
Old Mar 6, 2021 | 12:55 AM
matthewq4b's Avatar
matthewq4b
Why was the starter Alt and Battery replaced in the first place?
Old Mar 6, 2021 | 06:51 AM
Franklin2's Avatar
Franklin2
You can take your battery to the store and get it checked.
Old Mar 6, 2021 | 09:33 AM
Jluna126's Avatar
Jluna126
Because they were shot. I had them both tested
Old Mar 6, 2021 | 09:36 AM
Max Capacity's Avatar
Max Capacity
Just saying every now and then one get a bad battery that is new.
Do you have a volt meter ? Harbor Fright has free ones sometimes. I think I have three of them around the house and sheds.
Old Mar 6, 2021 | 09:47 AM
matthewq4b's Avatar
matthewq4b
And the starter?
Old Mar 6, 2021 | 09:59 AM
Max Capacity
Can you give us more background on this truck, did you just buy the truck or have you owned it for along time ?
I hope you understand its not normal for all these things to go at once...
Old Mar 6, 2021 | 12:44 PM
kr98664's Avatar
kr98664
You other guys okay? Kinda worried because the Battery Cable Bunch hasn’t chimed in yet and suggested replacing all of the cables just because. Hope you guys are well.
A bit of unrequested and over-rated troubleshooting philosophy for the original poster: See the link in post #2. Begin with a fully charged battery and spend ten minutes with a voltmeter. This test will confirm if your new battery and existing cables are up to snuff. If not, the test will pinpoint the exact fault. If all good, the next step is to check the charging system, to make sure the battery is getting a proper charge.
Old Mar 6, 2021 | 06:07 PM
matthewq4b's Avatar
matthewq4b
The testing procedure may not even be needed and may just need a visual... If the battery is getting dragged down that much by the starter there will be visual clues as to where the fault is. It may not be the battery cables or electrical at all, hence the request for more information. No point just blindly shooting in the dark. So just take a chill pill you can't do proper diagnostics with out information or even pick a direction to go.
Old Mar 6, 2021 | 08:09 PM
FuzzFace2's Avatar
FuzzFace2
Just for you Karl
We are good
If the battery cables look bad or of unknown age just replace them and never worry for a few more years
Listen to what they are saying on testing to find the weakest link
Dave ----
Old Mar 6, 2021 | 09:32 PM
kr98664's Avatar
kr98664
Phew! What a relief to know you're okay. Over 24 hours elapsed before you made your recommendation. Please don't worry us like that again in the future.
​​​​​​And FWIW, I still have the original factory cables in my truck, still going strong 37 years later. I did replace the short cable between the battery and starter relay as a precaution due to a little external corrosion, but the others are still original.
coleboy11
Jun 16, 2013 04:10 PM
DirtStripHero
16
Jun 9, 2008 05:58 PM
supercab blue
Dec 14, 2007 11:36 PM
Scalemaster
Mar 30, 2007 11:43 PM
orionfreak
Aug 26, 2004 10:01 AM
