engine misfire
Old Mar 5, 2021 | 06:38 PM
Jim Overcott's Avatar
Jim Overcott
engine misfire
just bought an 2006 e 150 with a 4.6 engine,,cats were stolen but o2 sensors still there,,having missing when using some power,,heavy miss,,but at idle with slight gas pedal touch it will smooth out,,,any ideas?
Old Mar 6, 2021 | 12:00 AM
NICKSAN's Avatar
NICKSAN
Did you replace the cats and if so with the correct ones for your vehicle?
Where the cats missing when you bought it?
Old Mar 6, 2021 | 08:01 AM
Jim Overcott
i didnt replace them yet,,,,just bought it,,and the cats had been stolen before i bought it,,,,,,,the oxygen sensors still there,cats gone,,,,,misfires heavy when power applied,,but feather the gas pedal at idle slightly?..will smooth out,,until you try to accelerate then misfire ,,,,and careful on the pedal will smooth some ,,,
Old Mar 6, 2021 | 08:03 AM
Jim Overcott
check engine light on but constant,,no flashing of the check engine light
Old Mar 7, 2021 | 04:00 AM
JWA's Avatar
JWA
That simply means there are confirmed DTC's saved in the PCM----you need to retrieve those "codes" in order to address the problems they indicate.
Old Mar 7, 2021 | 10:42 PM
Conanski's Avatar
Conanski
So it's got open headers basically. That is no good the exhaust has to be sealed up with pipe at least otherwise fresh air is mixing with the exhaust between pulses and messing up the O2 readings.
M H
Oct 1, 2019 12:29 PM
nick57
Jun 27, 2014 05:45 AM
Ed K
2004 - 2008 F150
13
Jan 24, 2013 04:28 PM
mwkobe
2004 - 2008 F150
Apr 9, 2011 06:38 AM
Ro Cobra
2004 - 2008 F150
18
Mar 15, 2007 11:44 AM
