View Poll Results: Is it doable to replace freeze plugs on 2003’ford expedition
Yes
0%
Not without mechanic present
0%
Impossible
0%
Easy to locate easy to do
0%
Dont buy it
100.00%
Its easy
0%
Voters: 3. You may not vote on this poll
Please help
Old Mar 4, 2021 | 11:50 AM
Dustin Cavallo's Avatar
Dustin Cavallo
Please help
I am looking to buy a 2003 expedition today, the woman describes it as running but needing a radiator (which I’ve already located and obtained)
my issue is that it also needs new freeze plugs and Altho I am very skilled and handy and have never been able to not fix something I just wanted to see if anyone knew: is it possible to remove/replace freeze plugs without removing entire engine bc ofcourse if that is the case, altho the plugs are cheap, I don’t have the means or equipment to lift the engine out of the body so my question is: does anyone know the location and count of freeze plugs in a 2003 Ford Expedition and if so is it possible for me to replace them all with then truck in tact or does it require taking the motor out! I am stranded and it appears to be a good deal I just know that i am not about to spend another couple of thousand dollars to buy a truck that I cannot fix without removing entire engine???? Please help fingers crossed that one of you is familiar with the same make and model otherwise i just can’t bring myself to do it. Google doesn’t specify what I need to know and it isn’t the same as talking with someone who’s dealt with this particular thing before
Old Mar 5, 2021 | 06:33 AM
broncoholic's Avatar
broncoholic
I can't imagine spending a couple thousand on a 2003 needing this kind of work. A thousand, maybe
Sorry, can't comment on the freeze plugs.
Old Mar 5, 2021 | 12:08 PM
lv2race's Avatar
lv2race
There are 10 freeze plugs. 3 on each side of the block that look to be accessible, 2 on the rear of the block which requires transmission removal, and 2 on the front behind the timing chain cover. I did this job on my Aerostar years ago and used a pneumatic driver to "walk in" the plugs. You can find videos on Youtube for Ford 5.4 freeze plug replacement.
saltydog463
18
Jan 19, 2016 08:59 AM
Chris100
Nov 13, 2014 01:33 PM
fixit5561
Mar 31, 2010 07:06 AM
fordboy67
Jan 27, 2008 07:25 AM
quick35th
Jul 26, 2005 10:14 PM
