Is this ok - safe?
Old Mar 3, 2021 | 02:14 PM
ford390gashog's Avatar
ford390gashog
Better check the size of the holes. Lots of the adjustable channels have gone to 11/16" holes instead of the old 5/8". The bolts also need to be torqued completely.
Old Mar 3, 2021 | 09:33 PM
MountainManRobb's Avatar
MountainManRobb
That would concern me for sure! Do the bolts fit in the channel holes tightly? If they are loose in the channel and hitch both, and upsized bolt may be your friend, and a couple shims for the side to side. I don't think it is going to be an "machinist" fit with no discernible slack at all, but it should definitely be better than that!
Old Mar 4, 2021 | 08:59 AM
1carguy's Avatar
1carguy
I took the trailer back to the dealer. Hopefully they can get some/most of the slop out of the hitch.
Old Mar 8, 2021 | 12:46 PM
1carguy's Avatar
1carguy
Dealer fixed the hitch. Job well done - no movement what so ever.
Old Mar 8, 2021 | 02:48 PM
HRTKD's Avatar
HRTKD
Good deal. Thanks for the update.
Old Mar 8, 2021 | 06:14 PM
FordmanNJ's Avatar
FordmanNJ
cool. What did the work intail?
Old Mar 9, 2021 | 09:59 AM
1carguy's Avatar
1carguy
The dealer welded inside the "U" part of the section that is attached to the trailer, and then ground the welds a little so the coupler would fit tightly in. That stopped the side to side movement. Then they welded steel at the back of the coupler to stop the up and down movement. The entire coupler fits in very tight, and I am good with what they did.
I do not understand why H&H manufactured the hitch like they did. Thanks for all your help.
brandonc17
Mar 18, 2018 03:52 PM
mrad
Nov 10, 2009 07:57 AM
ninerref
All Things Towing
Mar 10, 2005 10:40 AM
KJKozak2
All Things Towing
Apr 12, 2004 11:37 PM
Ratsmoker
All Things Towing
Feb 1, 2004 11:27 PM
